Datasheet MAX6001, MAX6002, MAX6003, MAX6004, MAX6005 (Analog Devices)
DescriptionLow-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References
Pages / Page12 / 1 — Low-Cost, Low-Power, Low-Dropout,. SOT23-3 Voltage References. …
File Format / SizePDF / 200 Kb
Low-Cost, Low-Power, Low-Dropout,. SOT23-3 Voltage References. MAX6001–MAX6005. General Description. Features
Datasheet MAX6001, MAX6002, MAX6003, MAX6004, MAX6005 Analog Devices
13-1395; Rev 1; 4/99
Low-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References MAX6001–MAX6005 General Description Features
The MAX6001–MAX6005 family of SOT23, low-cost ♦
1% max Initial Accuracy
series voltage references meets the cost advantage of shunt references and offers the power-saving advantage ♦
100ppm/°C max Temperature Coefficient
of series references, which traditionally cost more. Unlike ♦
45µA max Quiescent Supply Current
conventional shunt-mode (two-terminal) references that must be biased at the load current and require an exter- ♦
0.8µA/V Supply Current Variation with VIN
nal resistor, these devices eliminate the need for an ♦
±400µA Output Source and Sink Current
external resistor and offer a supply current that is virtually independent of the supply voltage. ♦
100mV Dropout at 400µA Load Current
These micropower, low-dropout, low-cost devices are ♦
0.12µV/µA Load Regulation
ideal for high-volume, cost-sensitive 3V and 5V battery- ♦ operated systems with wide variations in supply voltage
8µV/V Line Regulation
that require very low power dissipation. Additionally, ♦
Stable with CLOAD = 0 to 2.2nF
these devices are internally compensated and do not require an external compensation capacitor, saving valuable board area in space-critical applications.
Applications Ordering Information
Portable/Battery-Powered Equipment Notebook Computers
PIN- SOT PART TEMP. RANGE
PDAs, GPSs, and DMMs
PACKAGE TOP MARK
Cellular Phones
MAX6001
EUR-T -40°C to +85°C 3 SOT23-3 FZCW Pagers
MAX6002
EUR-T -40°C to +85°C 3 SOT23-3 FZCX Hard-Disk Drives
MAX6003
EUR-T -40°C to +85°C 3 SOT23-3 FZDK
MAX6004
EUR-T -40°C to +85°C 3 SOT23-3 FZCY
Selector Guide MAX6005
EUR-T -40°C to +85°C 3 SOT23-3 FZCZ
OUTPUT PART INPUT VOLTAGE (V) VOLTAGE (V)
MAX6001 1.250 2.5 to 12.6 MAX6002 2.500 (VOUT + 200mV) to 12.6 MAX6003 3.000 (VOUT + 200mV) to 12.6
Typical Operating Circuit
MAX6004 4.096 (VOUT + 200mV) to 12.6 MAX6005 5.000 (VOUT + 200mV) to 12.6 +SUPPLY INPUT (SEE SELECTOR GUIDE)
Pin Configuration
IN OUT REFERENCE OUT TOP VIEW MAX6001 * MAX6002 MAX6003 IN 1 MAX6004 MAX6001 MAX6005 MAX6002 3 GND 2.2nF MAX* MAX6003 GND MAX6004 OUT 2 MAX6005
SOT23-3
*CAPACITORS ARE OPTIONAL
________________________________________________________________ Maxim Integrated Products 1 For free samples & the latest literature: http://www.maxim-ic.com, or phone 1-800-998-8800. For small orders, phone 1-800-835-8769.
