Datasheet NE555, SA555, NA555 (Diodes)
ManufacturerDiodes
DescriptionPrecision Timers
Pages / Page14 / 1 — NE555/SA555/NA555. PRECISION TIMERS. Description. Pin Assignments. (Top …
File Format / SizePDF / 742 Kb
NE555/SA555/NA555. PRECISION TIMERS. Description. Pin Assignments. (Top View). SO-8. NEW PROD. Features. www.diodes.com
Datasheet NE555, SA555, NA555 Diodes
NE555/SA555/NA555 PRECISION TIMERS Description Pin Assignments
These devices are precision timing circuits capable of
(Top View)
producing accurate time delays or oscillation. In the time- delay or monostable mode of operation, the timed interval is controlled by a single external resistor and capacitor network. GND V CC In the astable mode of operation, the frequency and duty TRIG DISCH cycle can be controlled independently with two external resistors and a single external capacitor. OUT THRES The threshold and trigger levels normally are two-thirds and RESET CONT one-third, respectively, of VCC. These levels can be altered
T
by use of the control-voltage terminal. When the trigger input falls below the trigger level, the flip-flop is set, and the output
SO-8 UC
goes high. If the trigger input is above the trigger level and the threshold input is above the threshold level, the flip-flop is reset and the output is low. The reset (RESET) input can override all other inputs and can be used to initiate a new timing cycle. When RESET goes low, the flip-flop is reset, and the output goes low. When the output is low, a low- impedance path is provided between discharge (DISCH) and
NEW PROD
ground. The output circuit is capable of sinking or sourcing current up to 200mA. Operation is specified for supplies of 5V to 15V. With a 5-V supply, output levels are compatible with TTL inputs.
Features
• Timing from microseconds to hours • Astable or monostable operation • Adjustable duty cycle • TTL compatible output can source or sink up to 200mA • “Green” Molding Compound (No Br, Sb) • Lead Free Finish/ RoHS Compliant (Note 1) Notes: 1. EU Directive 2002/95/EC (RoHS). All applicable RoHS exemptions applied. Please visit our website at http://www.diodes.com/products/lead_free.html. NE555/SA555/NA555 1 of 14 February 2012 Document number: DS35112 Rev. 4 - 2
www.diodes.com
© Diodes Incorporated
