Datasheet VCNL3030X01 (Vishay)
ManufacturerVishay
DescriptionFully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function
Pages / Page16 / 1 — VCNL3030X01. Fully Integrated Proximity Sensor With Infrared Emitter,. …
File Format / SizePDF / 271 Kb
VCNL3030X01. Fully Integrated Proximity Sensor With Infrared Emitter,. I2C Interface, and Interrupt Function. FEATURES
Datasheet VCNL3030X01 Vishay
VCNL3030X01
Fully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function FEATURES
• Package type: surface-mount • Dimensions (L x W x H in mm): 4.0 x 2.36 x 0.75 • AEC-Q101 qualified • Integrated modules: infrared emitter (IRED), proximity sensor (PS), and signal conditioning IC • Low power consumption I2C (SMBus compatible) interface • Output type: I2C bus (PS) • Operation voltage: 2.5 V to 3.6 V V 1 DD 8 SDA • Floor life: 168 h, MSL 3, according to J-STD-020 SCL 2 7 INT • Material categorization: for definitions of compliance GND 3 6 LDR please see www.vishay.com/doc?99912 IR anode 4 5 IR cathode
PROXIMITY FUNCTION
• Immunity to red glow (940 nm IRED)
LINKS TO ADDITIONAL RESOURCES
• Programmable IRED sink current • Intelligent cancellation to reduce cross talk phenomenon
D 3 3 D A T
• Smart persistence scheme to reduce PS response time 3D Models Design Tools Application Technical Notes Notes • Selectable for 12- / 16-bit PS output data
DESCRIPTION INTERRUPT
VCNL3030X01 integrates a proximity sensor (PS) and a high power IRED into one small package. It incorporates • Programmable interrupt function for PS with upper and photodiodes, amplifiers, and analog to digital converting lower thresholds circuits into a single chip by CMOS process. The PS offers • Adjustable persistence to prevent false triggers for PS a programmable interrupt with individual high and low thresholds offers the power savings on the microcontroller.
• Force feedback applications • Proximity / optical switch for consumer, computing, automotive and industrial devices
PRODUCT SUMMARY OPERATING I2C BUS OPERATING IRED PULSE ADC RESOLUTION VOLTAGE VOLTAGE OUTPUT PART NUMBER RANGE (1) CURRENT (2) PROXIMITY / RANGE RANGE CODE (mm) (mA) AMBIENT LIGHT (V) (V)
VCNL3030X01 0 to 300 2.5 to 3.6 1.8 to 5.5 200 16 bit, I2C 16 bit / -
Notes
(1) Part should be operated in dark condition (not in direct sunlight) (2) Adjustable through I2C interface Rev. 1.0, 12-Aug-2020
1
Document Number: 84960 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
