Datasheet VCNL3030X01 (Vishay) - 10
Manufacturer | Vishay |
Description | Fully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function |
Pages / Page | 16 / 10 — VCNL3030X01. TABLE 3 - REGISTER: PS_CONF2 DESCRIPTION REGISTER: PS_CONF2. … |
File Format / Size | PDF / 271 Kb |
VCNL3030X01. TABLE 3 - REGISTER: PS_CONF2 DESCRIPTION REGISTER: PS_CONF2. COMMAND CODE: 0x03_H (0x03 DATA BYTE HIGH)
VCNL3030X01
TABLE 3 - REGISTER: PS_CONF2 DESCRIPTION REGISTER: PS_CONF2 COMMAND CODE: 0x03_H (0x03 DATA BYTE HIGH)
Command Bit Description Reserved 7 : 6 (0 : 0), reserved PS_Gain 5 : 4 (0 : 0) and (0 : 1) = two step mode, (1 : 0) = single mode x 8, (1 : 1) = single mode x 1 PS_HD 3 0 = PS output is 12 bits, 1 = PS output is 16 bits PS_NS 2 0 = typical sensitivity (two step mode x 4), 1 = typical sensitivity mode (two step mode) (0 : 0) = interrupt disable, (0 : 1) = trigger by closing, (1 : 0)= trigger by away, PS_INT 1 : 0 (1 : 1) = trigger by closing and away
TABLE 4 - REGISTER: PS_CONF3 DESCRIPTION REGISTER: PS_CONF3 COMMAND CODE: 0x04_L (0x04 DATA BYTE LOW)
Command Bit Description 0 = disabled = normal current, 1 = enabled = 1/10 of normal current, LED_I_LOW 7 with that the current is accordingly: 5 mA, 7.5 mA, 10 mA, 12 mA, 14 mA, 16 mA, 18 mA, 20 mA Reserved 6 : 5 (0 : 0) PS_SMART_PERS 4 0 = disable; 1 = enable PS smart persistence PS_AF 3 0 = active force mode disable (normal mode), 1 = active force mode enable 0 = no PS active force mode trigger, 1 = trigger one time cycle PS_TRIG 2 VCNL3030X01 output one cycle data every time host writes in ‘1’ to sensor.The state returns to ‘0’ automatically. PS_MS 1 0 = proximity normal operation with interrupt function, 1 = proximity detection logic output mode enable 0 = turn off sunlight cancel; 1 = turn on sunlight cancel PS_SC_EN 0 PS sunlight cancel function enable setting
TABLE 5 - REGISTER: PS_MS DESCRIPTION REGISTER: PS_MS COMMAND CODE: 0x04_H (0x04 DATA BYTE HIGH)
Command Bit Description Reserved 7 0 (0 : 0) = 1 x typical sunlight cancel current, (0 : 1) = 2 x typical sunlight cancel current, PS_SC_CUR 6 : 5 (1 : 0) = 4 x typical sunlight cancel current, (1 : 1) = 8 x typical sunlight cancel current PS_SP 4 0 = typical sunlight capability, 1 = 1.5 x typical sunlight capability PS_SPO 3 0 = output is 00h in sunlight protect mode, 1 = output is FFh in sunlight protect mode, (0 : 0 : 0) = 50 mA; (0 : 0 : 1) = 75 mA; (0 : 1 : 0) = 100 mA; (0 : 1 : 1) = 120 mA LED_I 2 : 0 (1 : 0 : 0) = 140 mA; (1 : 0 : 1) = 160 mA; (1 : 1 : 0) = 180 mA; (1 : 1 : 1) = 200 mA LED current selection setting
TABLE 6 - REGISTER PS_CANC_L AND PS_CANC_M DESCRIPTION COMMAND CODE: 0x05_L (0x05 DATA BYTE LOW) AND 0x05_H (0x05 DATA BYTE HIGH)
Register Bit Description PS_CANC_L 7 : 0 0x00 to 0xFF, PS cancellation level setting_LSB byte PS_CANC_M 7 : 0 0x00 to 0xFF, PS cancellation level setting_MSB byte
TABLE 7 - REGISTER: PS_THDL_L AND PS_THDL_M DESCRIPTION COMMAND CODE: 0x06_L (0x06 DATA BYTE LOW) AND 0x06_H (0x06 DATA BYTE HIGH)
Register Bit Description PS_THDL_L 7 : 0 0x00 to 0xFF, PS interrupt low threshold setting_LSB byte PS_THDL_M 7 : 0 0x00 to 0xFF, PS interrupt low threshold setting_MSB byte
TABLE 8 - REGISTER: PS_THDH_L AND PS_THDH_M DESCRIPTION COMMAND CODE: 0x07_L (0x07 DATA BYTE LOW) AND 0x07_H (0x07 DATA BYTE HIGH)
Register Bit Description PS_THDH_L 7 : 0 0x00 to 0xFF, PS interrupt high threshold setting_LSB byte PS_THDH_M 7 : 0 0x00 to 0xFF, PS interrupt high threshold setting_MSB byte Rev. 1.0, 12-Aug-2020
10
Document Number: 84960 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
