Datasheet K857PE (Vishay) - 2
ManufacturerVishay
Description4-Quadrant Silicon PIN Photodiode
Pages / Page7 / 2 — K857PE. BASIC CHARACTERISTICS, SINGLE QUADRANT. PARAMETER. TEST …
File Format / SizePDF / 247 Kb
K857PE. BASIC CHARACTERISTICS, SINGLE QUADRANT. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. BASIC CHARACTERISTICS
K857PE BASIC CHARACTERISTICS, SINGLE QUADRANT PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT BASIC CHARACTERISTICS
K857PE
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Forward voltage IF = 50 mA VF - 0.9 1.3 V Reverse dark current VR = 10 V, E = 0 Iro - 1 10 nA VR = 0 V, f = 1 MHz, E = 0 CD - 11 - pF Diode capacitance VR = 3 V, f = 1 MHz, E = 0 CD - 7 - pF Short circuit current Ee = 1 mW/cm2, λ = 850 nm Ik - 8.5 - μA Temperature coefficient of Ira Ee = 1 mW/cm2, VR = 5 V TKIra - 0.15 - %/K Ee = 1 mW/cm2, λ = 850 nm, VR = 5 V Ira 7 8.5 11 μA Reverse light current Ee = 1 mW/cm2, λ = 940 nm, VR = 5 V Ira - 5.7 - μA Angle of half sensitivity ϕ - ± 60 - ° Wavelength of peak sensitivity λp - 840 - nm Range of spectral bandwidth λ0.1 - 690 to 1050 - nm Rise time VR = 10 V, RL = 50 Ω, λ = 830 nm tr - 30 - ns Fall time VR = 10 V, RL = 50 Ω, λ = 830 nm tf - 30 - ns
(Tamb = 25 °C, unless otherwise specified) Values per quadrant q (q = 1, 2, 3, 4)
CROSS-TALK SPECIFICATION
Laser illumination (850 nm, 65 μm spot diameter, radiant power 0.7 mW) of center of PD quadrant 1 (q = 1), VR, q = 5 V applied to all quadrants (q = 1, 2, 3, 4)
ILLUMINATED MEASURED PARAMETER TYP. VALUE UNIT
Yes Ira_850_1 100 % No Ira_850_2 0.1 % No Ira_850_3 0.1 % No Ira_850_4 0.05 % Axis Title 1000 10000 V = 10 V R ) (nA 100 1000 rrent u C ine ne ne rk a 10 1st li 2nd l 2nd li 100 everse D R 1 - I ro 0.1 10 50 70 90 110 T - Ambient Temperature (°C) amb Fig. 1 - Reverse Dark Current vs. Ambient Temperature Rev. 1.0, 10-Sep-2020
2
Document Number: 80136 For technical questions, contact: detectortechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
