Datasheet PIC18F24/25K42 (Microchip) - 9
ManufacturerMicrochip
Description28-Pin, Low-Power High-Performance High-Temperature Microcontrollers
Pages / Page18 / 9 — PIC18F24/25K42. 2.2. Standard Operating Conditions. VDD — Operating …
File Format / SizePDF / 268 Kb
PIC18F24/25K42. 2.2. Standard Operating Conditions. VDD — Operating Supply Voltage(1). TA — Operating Ambient Temperature Range
PIC18F24/25K42 2.2 Standard Operating Conditions VDD — Operating Supply Voltage(1) TA — Operating Ambient Temperature Range
link to page 9 link to page 9
The standard operating conditions for any device are defined as: Operating Voltage: VDDMIN VDD VDDMAX Operating Temperature: TA_MIN TA TA_MAX
PIC18F24/25K42 VDDMIN (Fosc  32 MHz).. +2.7V VDDMIN (Fosc > 32 MHz).. +3.0V VDDMAX .. +5.5V
High Temperature TA_MIN.. -40°C TA_MAX.. +150°C
Note 1:
See Parameter Supply Voltage, DC Characteristics: Supply Voltage (High Temperature).
2.3 DC Characteristics TABLE 2-1: SUPPLY VOLTAGE (HIGH TEMPERATURE) PIC18F24/25K42 Standard Operating Conditions (u nless otherwise stated) Param Min. Max. Symbol Characteristic Typ.† Units Conditions No. +150°C +150°C Supply Voltage
2.7 — 5.5 V F D002 V OSC 32 MHz DD 3.0 — 5.5 FOSC 32 MHz † Data in “Typ.” column is at 3.0V, 25°C unless otherwise stated. These parameters are for design guidance only and are not tested.
FIGURE 2-1: VOLTAGE-FREQUENCY GRAPH, -40°C
TA
+150°C
5.5V
64 MHz (V) DD
3.0V
V
2.7V
32 MHz
0 4 8 16 32 64
Frequency (MHz) Note 1:
The shaded region indicates the permissible combinations of voltage and frequency.  2020 Microchip Technology Inc. DS40002113A-page 9 Document Outline Description Family Types Table of Contents 1.0 Device Overview 2.0 Electrical Characteristics TABLE 2-1: Supply Voltage (High Temperature) FIGURE 2-1: Voltage-Frequency Graph, -40°C £ Ta £ +150°C TABLE 2-2: DC Characteristics: Supply Current (Idd)(1,2) TABLE 2-3: DC Characteristics: Power-Down Currents (Ipd)(1,2,3) TABLE 2-4: Memory Specifications (150°C) TABLE 2-5: Internal Oscillator Parameters(1) FIGURE 3-2: Precision-Calibrated HFINTOSC Frequency Accuracy Over Device Vdd and Temperature TABLE 2-6: Reset, Watchdog Timer, Oscillator Start-up Timer, Power-up Timer, Brown-out Timer and Low-Power Brown-out Reset Specifications TABLE 2-7: High/Low-Voltage Detect Characteristics TABLE 2-8: Fixed Voltage Reference (FVR) Specifications Appendix A: Revision History Product ID System Trademarks Worldwide Sales
