Datasheet AOB66518L (Alpha & Omega)
ManufacturerAlpha & Omega
Description150V N-Channel MOSFET
Pages / Page6 / 1 — AOB66518L. 150V N-Channel MOSFET. General Description. Product Summary. …
File Format / SizePDF / 670 Kb
AOB66518L. 150V N-Channel MOSFET. General Description. Product Summary. Applications. TO-263. Top View. D2PAK. Bottom View
Datasheet AOB66518L Alpha & Omega
AOB66518L 150V N-Channel MOSFET General Description Product Summary
• Trench Power MOSFET V technology DS 150V • Combined of low RDS(ON) and wide safe operatiing area ID (at VGS=10V) 120A (SOA) RDS(ON) (at VGS=10V) < 5mΩ • Higher in-rush current enabled for faster start-up and RDS(ON) (at VGS=8V) < 5.6mΩ shorter down time • RoHS and Halogen-Free Compliant
Applications
100% UIS Tested 100% Rg Tested • Telecom Hot-Swap • Load switch Max Tj=175°C • BMS • Motor
TO-263 Top View D2PAK Bottom View
D D D G G S S S G
AOB66518L Orderable Part Number Package Type Form Minimum Order Quantity
AOB66518L TO-263 Tape & Reel 800
Absolute Maximum Ratings TA=25°C unless otherwise noted Parameter Symbol Maximum Units
Drain-Source Voltage VDS 150 V Gate-Source Voltage VGS ±20 V Continuous Drain TC=25°C 120 ID Current G TC=100°C 120 A Pulsed Drain Current C IDM 480 TA=25°C 30 Continuous Drain IDSM A Current TA=70°C 25 Avalanche Current C IAS 70 A Avalanche energy L=0.3mH C EAS 735 mJ Diode reverse recovery di/dt 500 A/us V ≤ ≤ DS=0 to 75V,IF 300A,TJ 125°C TC=25°C 375 PD W Power Dissipation B TC=100°C 185 TA=25°C 10 PDSM W Power Dissipation A TA=70°C 7 Junction and Storage Temperature Range TJ, TSTG -55 to 175 °C
Thermal Characteristics Parameter Symbol Typ Max Units
Maximum Junction-to-Ambient A t ≤ 10s 12 15 °C/W RqJA Maximum Junction-to-Ambient A D Steady-State 50 60 °C/W Maximum Junction-to-Case Steady-State RqJC 0.26 0.40 °C/W Rev.1.0: June 2020 www.aosmd.com Page 1 of 6
