Datasheet PVI5033RPbF (Infineon) - 2
Manufacturer | Infineon |
Description | Photovoltaic Isolator Solid-State |
Pages / Page | 5 / 2 — Series PVI5033RPbF. Electrical Specifications. INPUT CHARACTERISTICS. … |
Revision | 01_00 |
File Format / Size | PDF / 271 Kb |
Series PVI5033RPbF. Electrical Specifications. INPUT CHARACTERISTICS. Limits. Units. OUTPUT CHARACTERISTICS
Series PVI5033RPbF Electrical Specifications
(-40°C ≤ TA ≤ +85°C unless otherwise specified)
INPUT CHARACTERISTICS Limits Units
Min. Input Current (See Fig.1) 5.0 mA Input Current Range (See Fig. 1) 3.0 to 25 mA Max. Continuous Input Current @ TA=+25°C 40 mA LED Forward Voltage Drop @ 5mA, TA=+25°C (See Fig. 3) 1.4 V Max. Reverse Voltage 6.0 V Max. Reverse Current @ -6VDC, TA=+25°C 10 µA
OUTPUT CHARACTERISTICS Limits Units
Min. Forward Voltage 8.0 VDC Max. Reverse Current 10 µADC
COUPLED CHARACTERISTICS Limits Units
Min. Output Voltage @ ILED = 10mA, RL = 10MΩ 5 V @ TA=0°C to +70°C (See Fig. 1 & 2) Max. Output Voltage @ ILED = 10mA, RL = 10MΩ 10 V @ TA=0°C to +70°C (See Fig. 1 & 2) Max. Voltage Differential Between Outputs 1.0 V @ ILED = 5mA, RL = 10MΩ Min. Output Short-Circuit Current 1.65 µA @ ILED = 5mA, @ TA=+25°C (See Fig. 1 & 2) Typical Output Short-Circuit Current 5 µA @ ILED = 10mA, @ TA=+25°C (See Fig. 1 & 2) Max. Turn-On Time @ ILED = 5mA, CLOAD = 200pF (See Fig. 4) 2.5 ms Max. Turn-Off Time @ ILED = 5mA, CLOAD = 200pF (See Fig. 4) .5 ms Off-State Clamping Resistance: minimum 350 Ω maximum 1500 Ω
GENERAL CHARACTERISTICS Limits Units
Min. Dielectric Strength, Input-Output 3750 VRMS Min. Dielectric Strength, Output-to-Output 1200 VDC Min. Insulation Resistance, Input-to-Output 1012 Ω @TA=+25°C, 50%RH, 100VDC Max. Capacitance, Input-Output 5.0 pF Max. Pin Soldering Temperature (10 seconds max.) +260 °C Ambient Temperature Range: Operating -40 to +85 °C Storage -40 to +125 °C
Connection Diagram 1 8 (+)
International Rectifier does not recommend the use of this product in aerospace, avionics, military or life support
2 7 (-)
applications. Users of this International Rectifier product in such applications assume all risks of such use and in- demnify International Rectifier against all damages re-
3 6 (+)
sulting from such use.
4 5 (-)
2 www.irf.com © 2015 International Rectifier Submit Datasheet Feedback April 24, 2015
