Datasheet TCKE712BNL (Toshiba)
Manufacturer | Toshiba |
Description | 13.2 V, eFuse with Adjustable Over Current Protection |
Pages / Page | 15 / 1 — TCKE712BNL. 13.2 V, eFuse with Adjustable Over Current Protection. Over … |
File Format / Size | PDF / 632 Kb |
TCKE712BNL. 13.2 V, eFuse with Adjustable Over Current Protection. Over Voltage Protection and Slew Rate Control. Feature
TCKE712BNL TOSHIBA CMOS Linear Integrated Circuit Silicon Monolithic
TCKE712BNL 13.2 V, eFuse with Adjustable Over Current Protection Over Voltage Protection and Slew Rate Control
The TCKE712BNL is 13.2 V high input voltage Single Inputs- Single Output eFuse IC. It can be used as a reusable fuse, and other protection features like adjustable over current limit by an external resistor, short circuit protection, adjustable slew rate control by an external capacitance, adjustable over voltage protection, under voltage protection, thermal shutdown and FLAG function. Switch ON resistance is only 53 mΩ, Wide input voltage operation characteristics makes this product ideal for power management such as in the Power Stage of Hard disk drive and Battery Charge applications. This device is available in 0.5 mm pitch ultra small package WSON10 (3.0 mm x 3.0 mm, t: 0.7 mm (typ)) .Thus this device is ideal for various WSON10 application such as portable applications that require high-density board. Weight : 19.7 mg ( typ.)
Feature
High input voltage: VIN max = 13.2 V Low ON resistance : RON = 53 mΩ (typ.) Adjustable over current protection Adjustable over voltage protection Programmable Slew rate control by External Capacitance for Inrush current reduction FLAG indicates Reverse current blocking (SW OFF state) Thermal Shutdown Small package:WSON10 (3.0 mm x 3.0 mm, t: 0.7 mm (typ)) Start of commercial production 2020-11 © 2020 1 2020-12-14 Toshiba Electronic Devices & Storage Corporation
