Datasheet MAX907, MAX908, MAX909 (Maxim) - 4
Manufacturer | Maxim |
Description | Dual/Quad/Single, High-Speed, Ultra-Low-Power, Single-Supply TTL Comparators |
Pages / Page | 11 / 4 — Dual/Quad/Single, High-Speed, Ultra-Low-Power,. Single-Supply TTL … |
File Format / Size | PDF / 651 Kb |
Dual/Quad/Single, High-Speed, Ultra-Low-Power,. Single-Supply TTL Comparators MAX907/MAX908/MAX909
Dual/Quad/Single, High-Speed, Ultra-Low-Power, Single-Supply TTL Comparators MAX907/MAX908/MAX909 ELECTRICAL CHARACTERISTICS (continued)
(V+ = 5V,
TA = +25°C
; MAX909 only: V- = 0V, VLATCH = 0V; unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
V Propagation Delay t IN = 100mV, VOD = 5mV PD+, tPD- 40 50 ns (Note 9) V Differential Propagation Delay ∆t IN = 100mV, VOD = 5mV PD 1 ns (Note 10) MAX909 only: VIN = 100mV, Propagation Delay Skew tPDskew 2 ns VOD = 5mV (Note 11) Latch Input Voltage High VIH (Note 12) 2.0 V Latch Input Voltage Low VIL (Note 12) 0.8 V Latch Input Current IIH, IIL (Note 12) 20 µA Latch Setup Time ts (Note 12) 2 ns Latch Hold Time th (Note 12) 2 ns
(V+ = 5V,
TA = TMIN to TMAX
Positive Trip Point VTRIP+ (Note 1) 2 5 mV Negative Trip Point VTRIP- (Note 1) -2 -5 mV Input Offset Voltage VOS (Note 2) 1 3.5 mV Input Bias Current IB VCM = 0V, VIN = VOS 200 500 nA Input Offset Current IOS VCM = 0V, VIN = VOS 50 100 nA C/E temp. MAX907/MAX908/MAX909 -0.2 V+ - 1.5 ranges (Notes 3, 4) MAX909 only, V- = -5V -5.2 V+ - 1.5 Input Voltage Range VCMR V M temp. range MAX907MSA/PR -0.1 V+ - 1.5 (Notes 3, 4) Common-Mode Rejection Ratio CMRR (Notes 4, 5) 75 300 µV/V Power-Supply Rejection Ratio PSRR (Notes 4, 6) 75 400 µV/V Output High Voltage VOH ISOURCE = 100µA 2.8 3.5 V TA = TMAX 0.45 Output Low Voltage VOL ISINK = 3.2mA TMIN = 0°C 0.525 V TMIN = -40°C 0.550 Positive Supply Current per MAX907/MAX908 0.8 1.2 I+ (Note 7) mA Comparator MAX909 1.2 2.0 Negative Supply Current I- MAX909 only; V- = -5V 100 200 µV Power Dissipation per MAX907/MAX908 4 7 PD (Note 8) mW Comparator MAX909 6 11
_______________________________________________________________________________________ 3
Document Outline not-recomm-data-sheet-cover.pdf Not Recommended for New Designs not-recomm-data-sheet-coverMAX909.pdf Not Recommended for New Designs
