Datasheet LT3960 (Analog Devices) - 6
DescriptionI2C to CAN-Physical Transceiver
Pages / Page20 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, VCC = 3.3V, RPU = 60Ω …
TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, VCC = 3.3V, RPU = 60Ω unless otherwise noted
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VCC = 3.3V, RPU = 60Ω unless otherwise noted
LT3960
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VCC = 3.3V, RPU = 60Ω unless otherwise noted. Supply Current (I2CAN Dominant) Supply Current (I2CAN Recessive) Supply Current (I2CAN Dominant) vs VCC vs VCC vs Temperature
70 6.0 70 5.8 65 65 5.6 60 V 5.4 60 CC = 5V 55 5.2 55 (mA) (mA) 5.0 (mA) 50 I CC(D) I CC(R) 4.8 50 I CC(D) VCC = 3.3V 45 4.6 45 4.4 40 40 4.2 35 4.0 35 3 3.5 4 4.5 5 5.5 3 3.5 4 4.5 5 5.5 –50 –25 0 25 50 75 100 125 150 VCC (V) VCC (V) TEMPERATURE (˚C) 3960 G01 3960 G02 3960 G03
Supply Current (I2CAN Recessive) I2CAN Differential Output Voltage I2CAN Common Mode Voltage vs Temperature (Dominant) vs Temperature (Dominant) vs Temperature
5.5 3.4 2.7 5.4 2.6 3.2 VCC = 5V 5.3 VCC = 5V 2.5 5.2 3.0 2.4 5.1 2.8 2.3 (mA) (V) (V) 5.0 2.2 I CC VCC = 3.3V 4.9 2.6 V OD(D) V OC(D) 2.1 4.8 2.4 2.0 4.7 VCC = 3.3V 1.9 2.2 VCC = 3.3V 4.6 1.8 4.5 2.0 1.7 –50 –30 –10 10 30 50 70 90 110 130 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (˚C) TEMPERATURE (˚C) TEMPERATURE (˚C) 3960 G04 3960 G05 3960 G06
CANxH Short-Circuit Current CANxH Short-Circuit Current I2C to CAN Propagation Delay (Dominant) vs CANxH Voltage (Dominant) vs CANxH Voltage vs Temperature
0 100 70 –10 90 60 –20 80 DOMINANT –30 70 50 –40 VCC = 5V 60 VCC = 3.3V (mA) (mA) 40 (ns) –50 50 –60 V 30 CC = 3.3V 40 T PI2CB I CANXH(D) V I CANXL(D) CC = 5V –70 30 20 –80 20 10 RECESSIVE –90 10 –100 0 0 –40 –35 –30 –25 –20 –15 –10 –5 0 5 0 5 10 15 20 25 30 35 40 –50 –25 0 25 50 75 100 125 150 CANXH (V) CANXL (V) TEMPERATURE (˚C) 3960 G07 3960 G08 3960 G09 Rev. 0 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Switching Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuits Timing Diagrams Operation Applications Information Typical Applications Typical Application Related Parts
