Datasheet 2SA1381, KSA1381 (Fairchild) - 6
ManufacturerFairchild
DescriptionPNP Epitaxial Silicon Transistor
Pages / Page6 / 6 — 2SA1381/KSA1381 PNP Ep2SA1381/KSA1381. TRADEMARKS. axial Silico. n T. …
File Format / SizePDF / 171 Kb
2SA1381/KSA1381 PNP Ep2SA1381/KSA1381. TRADEMARKS. axial Silico. n T. ran. sistor. DISCLAIMER. LIFE SUPPORT POLICY
2SA1381/KSA1381 PNP Ep2SA1381/KSA1381 TRADEMARKS axial Silico n T ran sistor DISCLAIMER LIFE SUPPORT POLICY
The following are registered and unregistered trademarks and service marks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx® Green FPS™ Power247® SuperSOT™-8 Build it Now™ Green FPS™ e-Series™ POWEREDGE® SyncFET™ CorePLUS™ GTO™ Power-SPM™ The Power Franchise® CROSSVOLT™ i-Lo™ PowerTrench® CTL™ IntelliMAX™ Programmable Active Droop™
it
Current Transfer Logic™ ISOPLANAR™ QFET® TinyBoost™
axial Silico
EcoSPARK® MegaBuck™ QS™ TinyBuck™ MICROCOUPLER™ QT Optoelectronics™ TinyLogic® Fairchild® MicroFET™ Quiet Series™ TINYOPTO™ Fairchild Semiconductor® MicroPak™ RapidConfigure™ TinyPower™ FACT Quiet Series™ MillerDrive™ SMART START™ TinyPWM™ FACT® Motion-SPM™ SPM® TinyWire™
n T
FAST® OPTOLOGIC® STEALTH™ µSerDes™ FastvCore™ OPTOPLANAR® SuperFET™ UHC®
ran
FPS™ ® SuperSOT™-3 UniFET™
sistor
FRFET® PDP-SPM™ SuperSOT™-6 VCX™ Global Power ResourceSM Power220®
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component is any component of a life support which, (a) are intended for surgical implant into the body, or device or system whose failure to perform can be reasonably (b) support or sustain life, and (c) whose failure to perform expected to cause the failure of the life support device or when properly used in accordance with instructions for use system, or to affect its safety or effectiveness. provided in the labeling, can be reasonably expected to result in significant injury to the user.
PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition
This datasheet contains the design specifications for product development. Advance Information Formative or In Design Specifications may change in any manner without notice. This datasheet contains preliminary data; supplementary data will be pub- Preliminary First Production lished at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. This datasheet contains final specifications. Fairchild Semiconductor reserves No Identification Needed Full Production the right to make changes at any time without notice to improve design. This datasheet contains specifications on a product that has been discontin- Obsolete Not In Production ued by Fairchild semiconductor. The datasheet is printed for reference infor- mation only. Rev. I31 © 2008 Fairchild Semiconductor Corporation www.fairchildsemi.com 2SA1381/KSA1381 Rev. A1 6
