link to page 7 iMOTION™ IMD111T/IMD112T - Smart driver for motor controlMotor controller with integrated high-voltage gate driver2 Pin configurationTable 1Pin definitions and functions (continued)SignalTypeIMD111T IMD112T DescriptionMotor control COM P 9 9 Low side gate driver return LO1 O 12 12 Low side gate driver output - phase 1 LO2 O 11 11 Low side gate driver output - phase 2 LO3 O 10 10 Low side gate driver output - phase 3 VS1 P 19 19 High side gate driver return - phase 1 HO1 O 20 20 High side gate driver output - phase 1 VB1 P 21 21 High side gate driver positive power supply - phase 1 VS2 P 16 16 High side gate driver return - phase 2 HO2 O 17 17 High side gate driver output - phase 2 VB2 P 18 18 High side gate driver positive power supply - phase 2 VS3 P 13 13 High side gate driver return - phase 3 HO3 O 14 14 High side gate driver output - phase 3 VB3 P 15 15 High side gate driver positive power supply - phase 3 VDC AIN 36 36 DC bus sensing input ISS/IU AIN 40 40 Current sense input single shunt / phase U IV AIN 37 37 Current sense input phase V / analog input IW AIN 33 33 Current sense input phase W / analog input REFU 1) O 39 39 Itrip single shunt/phase U reference DAC output REFV AIN 38 38 Itrip phase V reference / analog input REFW AIN 32 32 Itrip phase W reference / analog input Hall sensor inputs AHALL1+ AIN 32 32 Analog Hall Element input 1 (+) AHALL1- AIN 33 33 Analog Hall Element input 1 (-) AHALL2+ AIN 38 38 Analog Hall Element input 2 (+) AHALL2- AIN 37 37 Analog Hall Element input 2 (-) HALL1 I 28 28 Digital Hall sensor input 1 HALL2 I 29 29 Digital Hall sensor input 2 HALL3 I 30 30 Digital Hall sensor input 3 Power factor correction PFCG0 O - 24 PFC gate drive 0 PFCG1 O - 25 PFC gate drive 1 (totem-pole PFC only) IPFC AIN - 34 PFC current sensing PFCREF AIN - 3 PFC Itrip comparator reference input PFCITRIP AIN - 4 PFC Itrip comparator input 1 This pin must have a filter capacitor connected to ground Datasheet 7 1.0 2020-12-4 Document Outline Features Potential applications Product validation Description Table of contents 1 Block diagram reference 2 Pin configuration 2.1 Pin definitions and functions 2.2 Pin configuration drawing IMD111T 2.3 Pin configuration drawing IMD112T 3 Functional description 3.1 Overview 3.2 Motion Control Engine 3.3 Gate Driver 3.4 Low Side Supply (VCC, VSS and COM) 3.5 High Side Supplies (VB1,2,3 and VS1,2,3) 3.6 Low and High Side Outputs (LO1,2,3 and HO1,2,3) 3.7 Internal Voltage Regulator 3.8 Application diagrams 4 Electrical characteristics and parameters 4.1 General parameters 4.1.1 Parameter Interpretation 4.1.2 Absolute maximum ratings 4.1.3 Pin Reliability in Overload 4.1.4 Operating Conditions 4.2 DC characteristics 4.2.1 Input/Output Characteristics 4.2.2 Analog to Digital Converter (ADC) 4.2.3 Analog comparator characteristics 4.2.4 Power Supply Current 4.2.5 Flash Memory Parameters 4.2.6 Static parameters gate driver 4.2.7 Static parameters voltage regulator 4.3 AC characteristics 4.3.1 Testing Waveforms 4.3.2 On-Chip Oscillator Characteristics 4.3.3 Dynamic parameters gate driver 4.3.4 Timing diagrams 4.4 Motor Control Parameters 4.4.1 PWM Characteristics 4.4.2 Current Sensing 4.4.3 Fault Timing 4.5 Power Factor Correction (PFC) parameters 4.5.1 Boost PFC characteristics 4.5.2 Totem Pole PFC characteristics 4.5.3 PFC Current Sensing 4.6 Control Interface Parameters 4.6.1 Control Input Interfaces 4.6.2 Serial Interface Parameters 4.6.2.1 UART Interface 4.6.3 Over Temperature Input 4.6.4 Pulse Output 5 Device and package specifications 5.1 Quality declaration 5.2 SBSL and Chip-IDs 5.3 Thermal considerations 5.4 Package Outline PG-LQFP-40-1 5.5 Part marking information Revision history Disclaimer
