Datasheet VEMD8081 (Vishay) - 3
Manufacturer | Vishay |
Description | Silicon PIN Photodiode |
Pages / Page | 6 / 3 — VEMD8081. PACKAGE DIMENSIONS |
File Format / Size | PDF / 156 Kb |
VEMD8081
www.vishay.com Vishay Semiconductors Axis Title 0° 10° 20° 100 10000 ) 30° 90 (% ity 80 tiv nsi 70 e 1000 40° S 60 1.0 ine ne ne ectral 50 2nd l p 0.9 50° 1st li 2nd li e S 40 v 100 30 0.8 60° elati R - Relative Sensitivity - 20 rel l. 70° re 0.7 M - Angular Displacement S S 10 80° 0 10 400 500 600 700 800 900 1000 1100 0.6 0.4 0.2 0 λ - Wavelength (nm) Fig. 5 - Relative Spectral Sensitivity vs. Wavelength Fig. 6 - Relative Sensitivity vs. Angular Displacement
PACKAGE DIMENSIONS
in millimeters Footprint 0.54 (x 8) 4.8 0.55 (x 8) 0.15 2.5 .38 1.63 2 Exposed pad connected to cathode 1.31 1.38 1.31 0.29 0.5 Not indicated tolerances ± 0.1 mm 2.4 0.48 ± 0.05 0.15 Pinning top view 1.31 1.38 1.31 PD pin 8 PD pin 7 PD pin 6 PD pin 5 cathode cathode cathode anode 2.15 4.32 1.25 PD pin 1 PD pin 2 PD pin 3 PD pin 4 cathode cathode cathode cathode 2.02 Pinning bottom view PD pin 1 PD pin 2 PD pin 3 PD pin 4 cathode cathode cathode cathode Optical center PD (0.14) (0.14) Pin 1 marking Technical drawings according to DIN PD pin 8 PD pin 7 PD pin 6 PD pin 5 specification. cathode cathode cathode anode Exposed pad connected to cathode Rev. 1.0, 07-Oct-2020
3
Document Number: 80218 For technical questions, contact: detectortechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
