Datasheet LT8698S, LT8698S-1 (Analog Devices) - 6
Description5V 3A Output, 42V Input USB Charger with Cable Drop Compensation and Dataline Protection
Pages / Page40 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
RevisionA
File Format / SizePDF / 4.5 Mb
link to page 2 link to page 16 LT8698S/LT8698S-1
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS 1A CHARGER PROFILE
HD+ Voltage VBUS/ISN = 5V 1.94 2.00 2.06 V HD+ Output Resistance 30 kΩ HD– Voltage VBUS/ISN = 5V 2.60 2.68 2.76 V HD– Output Resistance 23 kΩ
2A CHARGER PROFILE
HD+, HD– Voltage VBUS/ISN = 5V 1.2 1.25 1.35 V HD+, HD– Output Resistance 7.5 kΩ
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings temperature (TJ in °C) is calculated from the ambient temperature (TA in may cause permanent damage to the device. Exposure to any Absolute °C) and power dissipation (PD in Watts) according to the formula: Maximum Rating condition for extended periods may affect device TJ
TA + (PD
θJA) reliability and lifetime. where θJA (in
C/W) is the package thermal impedance.
Note 2:
The LT8698SE and LT8698SE-1 are guaranteed to meet
Note 3:
This IC includes overtemperature protection that is intended to performance specifications from 0
C to 125°C junction temperature. protect the device during overload conditions. Junction temperature will Specifications over the −40°C to 125°C operating junction temperature exceed 150°C when overtemperature protection is active. Continuous range are assured by design, characterization and correlation with operation above the specified maximum operating junction temperature statistical process controls. The LT8698SJ and LT8698SJ-1 are will reduce lifetime. guaranteed over the full −40°C to 150°C operating temperature range. High junction temperatures degrade operating lifetime. Operating lifetime
Note 4:
DUT configured in closed loop test circuit similar to page 36 CDP is de-rated at junction temperatures greater than 125°C. The junction charger application circuit.
Note 5:
Parameter not tested in production.
Note 6:
θ values are determined by simulation per JESD51 conditions, except θJA value is determined by simulation with demo board. See Applications Information section for more information on PCB layout considerations and example thermal data. Rev. A 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Related Parts
