Datasheet LT8606, LT8606B (Analog Devices) - 4
Description42V, 350mA Synchronous Step-Down Regulator with 2.5µA Quiescent Current
Pages / Page24 / 4 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 3:. Note 2:. TYPICAL …
RevisionD
File Format / SizePDF / 2.5 Mb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 3:. Note 2:. TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted
ELECTRICAL CHARACTERISTICS Note 1: Note 3: Note 2: TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted
LT8606/LT8606B
Stresses beyond those listed under Absolute Maximum Ratings temperature range. The LT8606H is guaranteed over the full –40°C to may cause permanent damage to the device. Exposure to any Absolute 150°C operating junction temperature range. High junction temperatures Maximum Rating condition for extended periods may affect device degrade operating lifetimes. Operating lifetime is derated at junction reliability and lifetime. Absolute Maximum Ratings are those values beyond temperatures greater than 125°C. which the life of a device may be impaired.
Note 3:
This IC includes overtemperature protection that is intended to
Note 2:
The LT8606E is guaranteed to meet performance specifications protect the device during overload conditions. Junction temperature will from 0°C to 125°C junction temperature. Specifications over the –40°C exceed 150°C when overtemperature protection is active. Continuous to 125°C operating junction temperature range are assured by design, operation above the specified maximum operating junction temperature characterization, and correlation with statistical process controls. The will reduce lifetime. LT8606I is guaranteed over the full –40°C to 125°C operating junction
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Efficiency (5V Output, Efficiency (5V Output, Efficiency (3.3V Output, Burst Burst Mode Operation) Burst Mode Operation) Mode Operation)
100 100 100 L = 10µH L = 10µH L = 6.8µH 95 fSW = 2MHz 90 fSW = 2MHz 95 fSW = 2MHz SYNC = 0V OR LT8606 DFN SYNC = 0V OR LT8606 DFN SYNC = 0V OR LT8606 DFN 90 80 90 85 70 85 80 60 80 75 50 75 70 40 70 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 65 30 65 60 20 60 55 VIN = 12V 10 VIN = 12V 55 VIN = 12V VIN = 24V VIN = 24V VIN = 24V 50 0 50 0 50 100 150 200 250 300 350 0.001 0.01 0.1 1 10 100 500 0 50 100 150 200 250 300 350 IOUT (mA) IOUT (mA) IOUT (mA) 8606 G01 8606 G02 8606 G03
Efficiency (3.3V Output, Burst Mode Operation) FB Voltage Load Regulation
100 780 0.20 L = 6.8µH 90 fSW = 2MHz 0.15 SYNC = 0V OR LT8606 DFN 80 779 0.10 70 (%) 60 TAGE (mV) 778 0.05 OUT 50 0.00 40 TION VOL 777 EFFICIENCY (%) –0.05 30 CHANGE IN V –0.10 20 776 FB REGULA 10 VIN = 12V –0.15 VIN = 24V 0 775 –0.20 0.001 0.01 0.1 1 10 100 500 –50 –10 30 70 110 150 0 50 100 150 200 250 300 350 IOUT (mA) TEMPERATURE (°C) OUTPUT CURRENT (mA) 8606 G04 8606 G05 8606 G06 Rev. D 4 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
