Datasheet LT8607, LT8607B (Analog Devices) - 2
Description | 42V, 750mA Synchronous Step-Down Regulator with 2.5µA Quiescent Current |
Pages / Page | 24 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
Revision | D |
File Format / Size | PDF / 3.0 Mb |
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LT8607/LT8607B
ABSOLUTE MAXIMUM RATINGS (Note 1)
VIN, EN/UV, PG ..42V Operating Junction Temperature Range (Note 2) FB, TR/SS . ...4V LT8607E .. –40°C to 125°C SYNC Voltage . ..6V LT8607I ... –40°C to 125°C LT8607J ... –40°C to 150°C LT8607H .. –40°C to 150°C Storage Temperature Range .. –65°C to 150°C
PIN CONFIGURATION
LT8607 LT8607-5 LT8607/LT8607B TOP VIEW TOP VIEW TOP VIEW 1 8 BST 1 10 EN/UV BST 1 10 EN/UV BST EN/UV SW 2 9 VIN SW 2 9 VIN SW 2 7 V 9 IN INTV 11 11 CC 3 8 PG INTVCC 3 8 PG GND RT 4 GND 7 TR/SS RT 4 GND 7 TR/SS INTVCC 3 6 PG SYNC 5 6 FB SYNC 5 6 VOUT RT 4 5 FB MSE PACKAGE MSE PACKAGE 10-LEAD PLASTIC MSOP 10-LEAD PLASTIC MSOP DC PACKAGE θJA = 40°C/W θJA = 40°C/W 8-LEAD (2mm × 2mm) PLASTIC DFN EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB θJA = 102°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB
LT8607EMSE#PBF LT8607EMSE#TRPBF LTGXJ 10-Lead Plastic MSOP –40°C to 125°C LT8607IMSE#PBF LT8607IMSE#TRPBF LTGXJ 10-Lead Plastic MSOP –40°C to 125°C LT8607HMSE#PBF LT8607HMSE#TRPBF LTGXJ 10-Lead Plastic MSOP –40°C to 150°C LT8607EMSE-5#PBF LT8607EMSE-5#TRPBF LTHNY 10-Lead Plastic MSOP –40°C to 125°C LT8607JMSE-5#PBF LT8607JMSE-5#TRPBF LTHNY 10-Lead Plastic MSOP –40°C to 150°C LT8607EDC#TRMPBF LT8607EDC#TRPBF LGXK 8-Lead Plastic (2mm × 2mm) DFN –40°C to 125°C LT8607IDC#TRMPBF LT8607IDC#TRPBF LGXK 8-Lead Plastic (2mm × 2mm) DFN –40°C to 125°C LT8607HDC#TRMPBF LT8607HDC#TRPBF LGXK 8-Lead Plastic (2mm × 2mm) DFN –40°C to 150°C LT8607BEDC#TRMPBF LT8607BEDC#TRPBF LGXM 8-Lead Plastic (2mm × 2mm) DFN –40°C to 125°C LT8607BIDC#TRMPBF LT8607BIDC#TRPBF LGXM 8-Lead Plastic (2mm × 2mm) DFN –40°C to 125°C LT8607BHDC#TRMPBF LT8607BHDC#TRPBF LGXM 8-Lead Plastic (2mm × 2mm) DFN –40°C to 150°C Rev. D 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
