Datasheet AD826 (Analog Devices) - 2
DescriptionHigh-Speed, Low-Power Dual Operational Amplifier
Pages / Page15 / 2 — AD826–SPECIFICATIONS (@ TA = +25. C, unless otherwise noted). Parameter. …
RevisionC
File Format / SizePDF / 738 Kb
AD826–SPECIFICATIONS (@ TA = +25. C, unless otherwise noted). Parameter. Conditions. Min. Typ. Max. Unit
AD826–SPECIFICATIONS (@ TA = +25 C, unless otherwise noted) Parameter Conditions Min Typ Max Unit
AD826–SPECIFICATIONS (@ TA = +25 C, unless otherwise noted) Parameter Conditions VS Min Typ Max Unit
DYNAMIC PERFORMANCE Unity Gain Bandwidth ±5 V 30 35 MHz ±15 V 45 50 MHz 0, +5 V 25 29 MHz Bandwidth for 0.1 dB Flatness Gain = +1 ±5 V 10 20 MHz ±15 V 25 55 MHz 0, +5 V 10 20 MHz Full Power Bandwidth1 VOUT = 5 V p-p RLOAD = 500 Ω ±5 V 15.9 MHz VOUT = 20 V p-p RLOAD = 1 kΩ ±15 V 5.6 MHz Slew Rate RLOAD = 1 kΩ ±5 V 200 250 V/µs Gain = –1 ±15 V 300 350 V/µs 0, +5 V 150 200 V/µs Settling Time to 0.1% –2.5 V to +2.5 V ±5 V 45 ns 0 V–10 V Step, AV = –1 ±15 V 45 ns to 0.01% –2.5 V to +2.5 V ±5 V 70 ns 0 V–10 V Step, AV = –1 ±15 V 70 ns NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion FC = 1 MHz ±15 V –78 dB Input Voltage Noise f = 10 kHz ±5 V, ±15 V 15 nV/√Hz Input Current Noise f = 10 kHz ±5 V, ±15 V 1.5 pA/√Hz Differential Gain Error NTSC ±15 V 0.07 0.1 % (R1 = 150 Ω) Gain = +2 ±5 V 0.12 0.15 % 0, +5 V 0.15 % Differential Phase Error NTSC ±15 V 0.11 0.15 Degrees (R1 = 150 Ω) Gain = +2 ±5 V 0.12 0.15 Degrees 0, +5 V 0.15 Degrees DC PERFORMANCE Input Offset Voltage ±5 V to ±15 V 0.5 2 mV TMIN to TMAX 3 mV Offset Drift 10 µV/°C Input Bias Current ±5 V, ±15 V 3.3 6.6 µA TMIN 10 µA TMAX 4.4 µA Input Offset Current ±5 V, ±15 V 25 300 nA TMIN to TMAX 500 nA Offset Current Drift 0.3 nA/°C Open-Loop Gain VOUT = ± 2.5 V ±5 V RLOAD = 500 Ω 2 4 V/mV TMIN to TMAX 1.5 V/mV RLOAD = 150 Ω 1.5 3 V/mV VOUT = ± 10 V ±15 V RLOAD = 1 kΩ 3.5 6 V/mV TMIN to TMAX 2 5 V/mV VOUT = ± 7.5 V ±15 V RLOAD = 150 Ω (50 mA Output) 2 4 V/mV INPUT CHARACTERISTICS Input Resistance 300 kΩ Input Capacitance 1.5 pF Input Common-Mode Voltage Range ±5 V +3.8 +4.3 V –2.7 –3.4 V ±15 V +13 +14.3 V –12 –13.4 V 0, +5 V +3.8 +4.3 V +1.2 +0.9 V Common-Mode Rejection Ratio VCM = ± 2.5 V, TMIN–TMAX ±5 V 80 100 dB VCM = ± 12 V ±15 V 86 120 dB T ± MIN to TMAX 15 V 80 100 dB –2– REV. C
