Datasheet AD827 (Analog Devices) - 3
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page12 / 3 — AD827. AD827J. AD827A/S. Model. Conditions. Min. Typ. Max. Unit. ABSOLUTE …
RevisionC
File Format / SizePDF / 228 Kb
AD827. AD827J. AD827A/S. Model. Conditions. Min. Typ. Max. Unit. ABSOLUTE MAXIMUM RATINGS1. ORDERING GUIDE. Temperature. Package. Range
AD827 AD827J AD827A/S Model Conditions Min Typ Max Unit ABSOLUTE MAXIMUM RATINGS1 ORDERING GUIDE Temperature Package Range
AD827 AD827J AD827A/S Model Conditions VS Min Typ Max Min Typ Max Unit
OUTPUT RESISTANCE Open Loop 15 15 Ω POWER SUPPLY Operating Range ±4.5 ±18 ±4.5 ±18 V Quiescent Current ±5 V 10 13 10 13 mA TMIN to TMAX 16 16.5/17.5 mA ±15 V 10.5 13.5 10.5 13.5 mA TMIN to TMAX 16.5 17/18 mA TRANSISTOR COUNT 92 92 NOTES 1 Offset voltage for the AD827 is guaranteed after power is applied and the device is fully warmed up. All other specifications are measured using high speed test equipment, approximately 1 second after power is applied. 2 Full Power Bandwidth = Slew Rate/2 π VPEAK. 3 Gain = +1, rising edge. All min and max specifications are guaranteed. Specifications subject to change without notice.
Supply Voltage . ± 18 V Internal Power Dissipation2
Temperature Package Package
Plastic (N) Package (Derate at 10 mW/°C) . 1.5 W
Model Range Description Option
Cerdip (Q) Package (Derate at 8.7 mW/°C) . 1.3 W AD827JN 0°C to +70°C 8-Lead Plastic DIP N-8 Small Outline (R) Package (Derate at 10 mW/°C) . 1.5 W AD827JR 0°C to +70°C 16-Lead Plastic SO R-16 LCC (E) Package (Derate at 6.7 mW/°C) . 1.0 W AD827AQ –40°C to +85°C 8-Lead Cerdip Q-8 Input Common-Mode Voltage . ± VS AD827SQ –55°C to +125°C 8-Lead Cerdip Q-8 Differential Input Voltage . 6 V AD827SQ/883B –55°C to +125°C 8-Lead Cerdip Q-8 Output Short Circuit Duration3 . Indefinite 5962-9211701MPA –55°C to +125°C 8-Lead Cerdip Q-8 Storage Temperature Range (N, R) . –65°C to +125°C AD827SE/883B –55°C to +125°C 20-Lead LCC E-20A Storage Temperature Range (Q) . –65°C to +150°C 5962-9211701M2A –55°C to +125°C 20-Lead LCC E-20A AD827JR-REEL 0°C to +70°C Tape & Reel Operating Temperature Range AD827JChips 0°C to +70°C Die AD827J . 0°C to 70°C AD827SChips –55°C to +125°C Die AD827A . –40°C to +85°C AD827S . –55°C to +125°C
METALLIZATION PHOTOGRAPH
Lead Temperature Range Contact factory for latest dimensions. (Soldering to 60 sec) . 300°C Dimensions shown in inches and (mm). NOTES Substrate is connected to V+. 1 Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only, and functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum ratings for extended periods may affect device reliability. 2 Maximum internal power dissipation is specified so that TJ does not exceed 175°C at an ambient temperature of 25°C. Thermal Characteristics: MiniDIP: θJA = 100°C/W; θJC = 33°C/ W Cerdip: θJA = 110°C/W; θJC = 30°C/W 16-Lead Small Outline Package: θJA = 100°C/W 20-Lead LCC: θ θ JA = 150°C/W; JC = 35°C/W 3 Indefinite short circuit duration is only permissible as long as the absolute maximum power rating is not exceeded. REV. C –3– Document Outline FEATURES CONNECTION DIAGRAMS PRODUCT DESCRIPTION APPLICATION HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALLIZATION PHOTOGRAPH Typical Performance Characteristics INPUT PROTECTION PRECAUTIONS VIDEO LINE DRIVER A HIGH SPEED THREE OP AMP INSTRUMENTATION AMPLIFIER CIRCUIT A TWO-CHIP VOLTAGE-CONTROLLED AMPLIFIER (VCA) WITH EXPONENTIAL RESPONSE Guidelines for Grounding and Bypassing OUTLINE DIMENSIONS Revision History
