Datasheet AD827 (Analog Devices) - 5
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page12 / 5 — AD827. 400. RISE. 350. AV = +1 SLEW RATE 10 – 90%. 300. FALL. VS =. 15V. …
RevisionC
File Format / SizePDF / 228 Kb
AD827. 400. RISE. 350. AV = +1 SLEW RATE 10 – 90%. 300. FALL. VS =. 15V. 250. 200. SLEW RATE – Volts/µs. 150. 100. –60 –40. –20. 120 140. TEMPERATURE –
AD827 400 RISE 350 AV = +1 SLEW RATE 10 – 90% 300 FALL VS = 15V 250 200 SLEW RATE – Volts/µs 150 100 –60 –40 –20 120 140 TEMPERATURE –
AD827
Figure 10. Open-Loop Gain and Figure 11. Open-Loop Gain Figure 12. Power Supply Rejection Phase Margin vs. Frequency vs. Load Resistance Ratio vs. Frequency Figure 15. Output Swing and Figure 13. Common-Mode Figure 14. Large Signal Error vs. Settling Time Rejection Ratio vs. Frequency Frequency Response
15V 250 RISE 200 SLEW RATE – Volts/µs FALL VS =
5V 150 100 –60 –40 –20 0 20 40 60 80 100 120 140 TEMPERATURE –
C
Figure 16. Harmonic Distortion Figure 17. Input Voltage Figure 18. Slew Rate vs. vs. Frequency Noise Spectral Density Temperature REV. C –5– Document Outline FEATURES CONNECTION DIAGRAMS PRODUCT DESCRIPTION APPLICATION HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALLIZATION PHOTOGRAPH Typical Performance Characteristics INPUT PROTECTION PRECAUTIONS VIDEO LINE DRIVER A HIGH SPEED THREE OP AMP INSTRUMENTATION AMPLIFIER CIRCUIT A TWO-CHIP VOLTAGE-CONTROLLED AMPLIFIER (VCA) WITH EXPONENTIAL RESPONSE Guidelines for Grounding and Bypassing OUTLINE DIMENSIONS Revision History
