Datasheet LTC2066, LTC2067, LTC2068 (Analog Devices) - 10
Description10µA Supply Current, Low IB, Zero-Drift Operational Amplifier
Pages / Page30 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. Closed Loop Output Impedance. Output …
File Format / SizePDF / 5.0 Mb
TYPICAL PERFORMANCE CHARACTERISTICS. Closed Loop Output Impedance. Output Impedance in Shutdown. vs Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Closed Loop Output Impedance Output Impedance in Shutdown vs Frequency
LTC2066/LTC2067/LTC2068
TYPICAL PERFORMANCE CHARACTERISTICS Closed Loop Output Impedance Output Impedance in Shutdown vs Frequency vs Frequency
1M 1G VS = 5V VS = 5V AV = +1 A 100k V = +1 100M 10k 10M 1k (Ω) (Ω) 1M Z OUT 100 Z OUT 100k 10 1 10k 0.1 1k 10 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) 2066 G34 2066 G35
Maximum Undistorted Output THD vs Frequency Amplitude vs Frequency Supply Current vs Supply Voltage
) –20 6 P–P 12.5 AV = +1 VS = ±2.5V V 5 –40 OUT = ±2V TAGE (V 10.0 TION (dB) 4 –60 7.5 3 TED OUTPUT VOL –80 5.0 2 A PER AMPLIFIER (µA) V = +1 I S T AL HARMONIC DISTOR A = 125°C –100 VS = ±2.5V 1 2.5 TA = 85°C TOT THD < –40dB RL = 10k T R A = 25°C R L = 499k L = 499k TA = –40°C –120 0 0 20 100 1k 2k MAXIMUM UNDISTOR 100 1k 10k 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 FREQUENCY (Hz) FREQUENCY (Hz) VS (V) 2066 G36 2066 G37 2066 G38
Supply Current vs SHDN Pin Supply Current vs SHDN Pin Supply Current vs Temperature Voltage Voltage
12 80 16 VS = 1.8V VS = 5V 125°C VS = 1.8V 125°C V 11 S = 5V 70 85°C 14 85°C 25°C 25°C 60 –40°C 12 –40°C 10 50 10 9 40 8 8 30 6 PER AMPLIFIER (µA) 7 PER AMPLIFIER (µA) PER AMPLIFIER (µA) I S I S 20 I S 4 6 10 2 5 0 0 –50 –25 0 25 50 75 100 125 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 TEMPERATURE (°C) SHDN PIN VOLTAGE (V) SHDN PIN VOLTAGE (V) 2066 G39 2066 G40 2066 G41 Rev. B 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Revision History Typical Application Related Parts
