Datasheet AD8042 (Analog Devices) - 7
Description | Dual 160 MHz Rail-to-Rail Amplifier |
Pages / Page | 16 / 7 — AD8042. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = 5V. T = 25°C. 140 … |
Revision | E |
File Format / Size | PDF / 335 Kb |
AD8042. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = 5V. T = 25°C. 140 PARTS, SIDE 1 & 2. MEAN = –1.52mV STD DEVIATION = 1.15
AD8042 TYPICAL PERFORMANCE CHARACTERISTICS 100 100 VS = 5V VS = 5V 90 T = 25°C T = 25°C 140 PARTS, SIDE 1 & 2 95 80 MEAN = –1.52mV STD DEVIATION = 1.15 ) 70 SAMPLE SIZE = 280 (140 AD8042s) 90 (dB Y 60 IN C N E GA U 50 85 Q E OOP 40 FR -L N E 80 30 OP 20 75 10
05 0 008 9- 9- 05 05
0
01
70
01
–6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6 0 250 500 750 1000 1250 1500 1750 2000 VOS (mV) LOAD RESISTANCE (Ω)
Figure 5. Typical Distribution of VOS Figure 8. Open-Loop Gain vs. RL to 2.5 V
30 VS = 5V 100 MEAN = –12.6µV/°C VS = 5V STD DEVIATION = 2.02µV/°C 25 RL = 1kΩ SAMPLE SIZE = 60 98 20 ) 96 Y C (dB N IN E 94 U 15 Q GA E FR OOP 92 10 -L N E OP 90 5
06 0
88
9- 05 009
0
01 9- 05
–18 –16 –14 –12 –10 –8 –6 –4 –2 0 86
01
V –40 –20 0 20 40 60 80 OS DRIFT (µV/°C) TEMPERATURE (°C)
Figure 6. VOS Drift Over −40°C to +85°C Figure 9. Open-Loop Gain vs. Temperature
0 VS = 5V 100 –0.2 VCM = 0V VS = 5V –0.4 90 A) RL = 500Ω TO 2.5V µ –0.6 ( ) NT –0.8 80 (dB IN URRE –1.0 C GA 70 AS R –1.2 L = 50Ω TO 2.5V BI OOP -L UT –1.4 N E 60 INP OP –1.6 –1.8 50
007 9- 05 010
–2.0
01 9- 05
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 40
01
TEMPERATURE (°C) 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 OUTPUT VOLTAGE (V)
Figure 7. I B vs. Temperature Figure 10. Open-Loop Gain vs. Output Voltage Rev. E | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION CIRCUIT DESCRIPTION DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY Single-Supply Composite Video Line Driver Single-Ended-to-Differential Driver Single-Supply Differential A/D Driver HDSL Line Driver LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
