Datasheet ADL8150ACHIP (Analog Devices)
DescriptionGaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz
Pages / Page14 / 1 — GaAs, HBT, MMIC, Low Phase Noise. Amplifier, 6 GHz to 14 GHz. Data Sheet. …
File Format / SizePDF / 289 Kb
GaAs, HBT, MMIC, Low Phase Noise. Amplifier, 6 GHz to 14 GHz. Data Sheet. ADL8150ACHIP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADL8150ACHIP Analog Devices
GaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz Data Sheet ADL8150ACHIP FEATURES FUNCTIONAL BLOCK DIAGRAM Output P1dB: 19 dBm (typical at 7 GHz to 11 GHz) P ADL8150ACHIP SAT: 23 dBm (typical at 7 GHz to 14 GHz) Gain: 13 dB (typical at 7 GHz to 11 GHz) Output IP3: 31.5 dBm (typical at 7 GHz to 11 GHz) RFOUT/VCC Phase noise: −172 dBc/Hz at 10 kHz offset 2 RFIN 1 VCC: 5 V at ICQ = 76 mA Die size: 1.490 mm × 0.930 mm × 0.102 mm APPLICATIONS
001
Military and space
23557-
Test instrumentation
Figure 1.
GENERAL DESCRIPTION
The ADL8150ACHIP is a self biased, gallium arsenide (GaAs), supply current (ICQ) from a 5 V supply voltage (VCC). The monolithic microwave integrated circuit (MMIC), heterojunction ADL8150ACHIP also features inputs and outputs (I/Os) that are bipolar transistor (HBT), low phase noise amplifier that operates internal y matched to 50 Ω and facilitates integration into from 6 GHz to 14 GHz. The amplifier provides 13 dB of gain, multichip modules (MCMs). Al data is taken with the chip 19 dBm output power for 1 dB gain compression (P1dB), and connected via two wire bonds that are 0.025 mm (1 mil) wide and an output third-order intercept (IP3) of 31.5 dBm at 7 GHz to 0.31 mm (12 mil) long. 11 GHz. The amplifier requires 76 mA of quiescent col ector
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Frequency Range: 6 GHz to 7 GHz Frequency Range: 7 GHz to 11 GHz Frequency Range: 11 GHz to 14 GHz Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8150ACHIP ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Handling Precautions Mounting Wire Bonding Assembly and Typical Application Circuit Diagrams Outline Dimensions Ordering Guide
