Datasheet HMC1131 (Analog Devices)
DescriptionGaAs, pHEMT, MMIC, Medium Power Amplifier, 24 GHz to 35 GHz
Pages / Page15 / 1 — GaAs, pHEMT, MMIC, Medium Power. Amplifier, 24 GHz to 35 GHz. Data Sheet. …
RevisionC
File Format / SizePDF / 491 Kb
GaAs, pHEMT, MMIC, Medium Power. Amplifier, 24 GHz to 35 GHz. Data Sheet. HMC1131. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC1131 Analog Devices, Revision: C
GaAs, pHEMT, MMIC, Medium Power Amplifier, 24 GHz to 35 GHz Data Sheet HMC1131 FEATURES FUNCTIONAL BLOCK DIAGRAM High saturated output power (P 1 2 3 4 SAT): 25 dBm C DD DD DD DD C NI V V V V NI High output third-order intercept (IP3): 35 dBm High gain: 22 dB (24 GHz to 27 GHz) 24 23 22 21 20 19 High output power for 1 dB compression (P1dB): 24 dBm NIC 1 18 NIC DC supply: 5 V at 225 mA GND 2 17 GND Compact 24-lead, 4 mm × 4 mm LCC package RFIN 3 16 RFOUT 1.5kΩ 1.5kΩ APPLICATIONS GND 4 15 GND NIC 5 14 NIC Point-to-point radios HMC1131 NIC 6 13 NIC Point-to-multipoint radios 7 8 9 VSAT and SATCOM 10 11 12 C 1 C C 2 C PACKAGE
001
NI BASE GG NI NI GG NI V V
13105- Figure 1.
GENERAL DESCRIPTION
The HMC1131 is a gallium arsenide (GaAs), pseudomorphic The HMC1131 is capable of supplying 25 dBm of saturated output high electron mobility transfer (pHEMT), monolithic microwave power and is housed in a compact, 4 mm × 4 mm ceramic integrated circuit (MMIC), driver amplifier that operates from leadless chip carrier (24-lead LCC). The HMC1131 is an ideal 24 GHz to 35 GHz. The HMC1131 provides 22 dB of gain at the driver amplifier for a wide range of applications, including 24 GHz to 27 GHz range, 35 dBm output IP3, and 24 dBm of point-to-point radios, from 24 GHz to 35 GHz. output power at 1 dB gain compression, while requiring 225 mA from a 5 V supply.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY ELECTRICAL SPECIFICATIONS 24 GHz TO 27 GHz FREQUENCY RANGE 27 GHz TO 35 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION EVALUATION PCB Bill of Materials TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
