Datasheet ADL5606 (Analog Devices)
Description | 1800 MHz TO 2700 MHz, 1 W RF Driver Amplifier |
Pages / Page | 18 / 1 — 1800 MHz to 2700 MHz,. 1 W RF Driver Amplifier. Data Sheet. ADL5606. … |
Revision | C |
File Format / Size | PDF / 428 Kb |
1800 MHz to 2700 MHz,. 1 W RF Driver Amplifier. Data Sheet. ADL5606. FEATURES. FUNCTIONAL BLOCK DIAGRAM
1800 MHz to 2700 MHz, 1 W RF Driver Amplifier Data Sheet ADL5606 FEATURES FUNCTIONAL BLOCK DIAGRAM Operation from 1800 MHz to 2700 MHz C C C C N N N N 6 5 4 3 Gain of 24.3 dB at 2140 MHz 1 1 1 1 OIP3 of 45.5 dBm at 2140 MHz P1dB of 30.8 dBm at 2140 MHz RFIN 1 12 RFOUT Noise figure of 4.7 dB at 2140 MHz DISABLE 2 PWDN 11 RFOUT Power supply: 5 V VCC 3 VBIAS 10 RFOUT Power supply current: 362 mA typical Internal active biasing VBIAS 4 9 RFOUT ADL5606 Fast power-up/power-down function
1
Compact 4 mm × 4 mm, 16-lead LFCSP 5 6 7 8
-00 8
C C C C
96
ESD rating of ±1 kV (Class 1C) N N N N
09
Pin-compatible with the ADL5605 (7 00 MHz to 1000 MHz)
Figure 1.
APPLICATIONS Wireless infrastructure Automated test equipment ISM/AMR applications 0 GENERAL DESCRIPTION –10
The ADL5606 is a broadband, two-stage, 1 W RF driver
–20
amplifier that operates over a frequency range of 1800 MHz
–30
to 2700 MHz. The device can be used in a wide variety of
c) B
wired and wireless applications, including ISM, MC-GSM,
(d –40 R P
W-CDMA, TD-SCDMA, and LTE.
AC –50
The ADL5606 operates on a 5 V supply voltage and a supply
–60
current of 362 mA. The driver also incorporates a fast power-
2140 MHz
up/power-down function for TDD applications, applications
–70
that require a power saving mode, and applications that
–80
intermittently transmit data.
0 2 4 6 8 10 12 14 16 18 20 22
002 8-
POUT (dBm)
0996 The ADL5606 is fabricated on a GaAs HBT process and is Figure 2. ACPR vs. Output Power, 3GPP, TM1-64, at 2140 MHz packaged in a compact 4 mm × 4 mm, 16-lead LFCSP that uses an exposed paddle for excellent thermal impedance. The ADL5606 operates from −40°C to +85°C. A fully populated evaluation board tuned to 2140 MHz is also available.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2011–2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 1960 MHZ FREQUENCY TUNING BAND 2140 MHZ FREQUENCY TUNING BAND 2630 MHZ FREQUENCY TUNING BAND GENERAL APPLICATIONS INFORMATION BASIC LAYOUT CONNECTIONS Power Supply RF Input Interface RF Output Interface Power-Down ADL5606 MATCHING ACPR AND EVM THERMAL CONSIDERATIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
