Datasheet ADL5605 (Analog Devices) - 3
Description700 MHz TO 1000 MHz, 1 W RF Driver Amplifier
Pages / Page18 / 3 — Data Sheet. ADL5605. SPECIFICATIONS. Table 1. Parameter. Test …
RevisionB
File Format / SizePDF / 520 Kb
Data Sheet. ADL5605. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5605 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4
VCC1 = 5 V and TA = 25°C, unless otherwise noted.1
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 700 1000 MHz FREQUENCY = 748 MHz ± 20 MHz Gain 24.3 dB vs. Frequency ±20 MHz +0.01/−0.19 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.8 dB vs. Supply 4.75 V to 5.25 V ±0.07 dB Output 1 dB Compression Point (P1dB) 31.4 dBm vs. Frequency ±20 MHz −0.68/+0.08 dB vs. Temperature −40°C ≤ TA ≤ +85°C +0.94/−1.99 dB vs. Supply 4.75 V to 5.25 V −0.24/−0.05 dB Output Third-Order Intercept (OIP3) ∆f = 1 MHz, POUT = 14 dBm per tone 41.9 dBm vs. Frequency ±20 MHz −0.22/+0.16 dB vs. Temperature −40°C ≤ TA ≤ +85°C +0.07/−1.56 dB vs. Supply 4.75 V to 5.25 V +0.04/+0.09 dB Noise Figure 4.8 dB FREQUENCY = 881 MHz ± 13 MHz Gain 23.0 dB vs. Frequency ±13 MHz −0.03/−0.08 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point (P1dB) 31.4 dBm vs. Frequency ±13 MHz −0.18/−0.11 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.6 dB vs. Supply 4.75 V to 5.25 V −0.4/+0.3 dB Output Third-Order Intercept (OIP3) ∆f = 1 MHz, POUT = 14 dBm per tone 43.4 dBm vs. Frequency ±13 MHz −0.32/+0.40 dB vs. Temperature −40°C ≤ TA ≤ +85°C −0.19/−0.99 dB vs. Supply 4.75 V to 5.25 V +0.21/−0.03 dB Noise Figure 4.7 dB FREQUENCY = 943 MHz ± 18 MHz Gain 23.0 dB vs. Frequency ±18 MHz +0.28/−0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.8 dB vs. Supply 4.75 V to 5.25 V ±0.04 dB Output 1 dB Compression Point (P1dB) 30.9 dBm vs. Frequency ±18 MHz +0.39/−0.08 dB vs. Temperature −40°C ≤ TA ≤ +85°C +0.7/−0.9 dB vs. Supply 4.75 V to 5.25 V −0.43/+0.35 dB Adjacent Channel Power Ratio (ACPR) POUT = 18 dBm, one-carrier W-CDMA, 51 dBc 64 DPCH, frequency = 946 MHz Output Third-Order Intercept (OIP3) ∆f = 1 MHz, POUT = 14 dBm per tone 44.2 dBm vs. Frequency ±18 MHz −0.47/−0.10 dB vs. Temperature −40°C ≤ TA ≤ +85°C +0.7/−1.6 dB vs. Supply 4.75 V to 5.25 V −0.08/+0.07 dB Noise Figure 4.8 dB Rev. B | Page 3 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 748 MHZ FREQUENCY TUNING BAND 881 MHZ FREQUENCY TUNING BAND 943 MHZ FREQUENCY TUNING BAND GENERAL APPLICATIONS INFORMATION BASIC LAYOUT CONNECTIONS Power Supply RF Input Interface RF Output Interface Power-Down ADL5605 MATCHING ACPR AND EVM THERMAL CONSIDERATIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
