Datasheet HMC789ST89E (Analog Devices) - 7
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
Pages / Page16 / 7 — HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Input …
File Format / SizePDF / 716 Kb
HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Input Return Loss vs. Output Return Loss vs
HMC789ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Input Return Loss vs Output Return Loss vs
HMC789ST89E
v02.0314
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Input Return Loss vs. Output Return Loss vs. Temperature @ 2600 MHz Temperature @ 2600 MHz
0 0 T M -5 +25 C ) +85 C +25 C ) - 40 C -5 +85 C - 40 C (dB (dB S -10 S S S LO LO -10 K - S N N R -15 R U U C T T E E R R -15 -20 LO -25 -20 2.3 2.4 2.5 2.6 2.7 2.8 2.3 2.4 2.5 2.6 2.7 2.8 IN B FREQUENCY (GHz) FREQUENCY (GHz) A
P1dB vs. Temperature @ 2600 MHz Psat vs. Temperature @ 2600 MHz
R & G 26 28 E 27 IV 25 R 26 (dBm) 24 (dBm) 25 P1dB Psat +25 C S - D 24 +85 C 23 - 40 C R +25 C +85 C - 40 C 23 IE 22 22 2.3 2.4 2.5 2.6 2.7 2.8 2.3 2.4 2.5 2.6 2.7 2.8 LIF FREQUENCY (GHz) FREQUENCY (GHz) P M A
Output IP3 vs. Temperature @ 2600 MHz Output IP3 vs. Output Power @ 2600 MHz
50 50 45 45 (dB) 40 (dB) 40 IP3 IP3 35 +25 C 35 +25 C +85 C +85 C - 40 C - 40 C 30 30 2.3 2.4 2.5 2.6 2.7 2.8 0 2 4 6 8 10 12 14 16 18 FREQUENCY (GHz) SINGLE TONE POUT (dBm) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
