Datasheet HMC635 (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 18 -40 GHz
Pages / Page8 / 6 — HMC635. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Pad Descriptions. …
File Format / SizePDF / 410 Kb
HMC635. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Pad Descriptions. 2 - 63
HMC635 GaAs PHEMT MMIC DRIVER AMPLIFIER, 18 - 40 GHz Pad Descriptions 2 - 63
HMC635
v00.1107
Pad Number Function Description Interface Schematic This pad is AC coupled 2 1 RFIN and matched to 50 Ohms. Vdd1, Vdd2, Vdd3, Power Supply Voltage for the amplifi er. See assembly 2, 3, 4, 5 IP Vdd4 diagram for required external components. H This pad is AC coupled 6 RFOUT and matched to 50 Ohms. - C S R Gate control for amplifi er, please follow “MMIC Amplifi er 7, 8 Vgg2, Vgg1 Biasing Procedure” application note. See assembly dia- IE gram for required external components. IF L P Die Bottom GND Die bottom must be connected to RF/DC ground. M K A OC BL IN A & G R E IV R D Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Pho - n25 e 0 : 7 - 81 3 - 3 32 4 9-3 F 470 ax: 978 0 • Orde - r o 25 nlin 0- e a 3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
2 - 63
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
