Datasheet HMC634LC4 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5 -20 GHz
Pages / Page8 / 3 — HMC634LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Power …
File Format / SizePDF / 434 Kb
HMC634LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Power Compression @ 12.5 GHz. Power Compression @ 20 GHz
HMC634LC4 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5 - 20 GHz Power Compression @ 12.5 GHz Power Compression @ 20 GHz
HMC634LC4
v03.0514
30 30 T Pout (dBm) (%) 25 (%) 25 Gain (dB) M PAE (%) PAE PAE 20 20 (dB), (dB), 15 15 S - S GAIN GAIN R 10 10 (dBm), Pout (dBm) (dBm), IE 5 Gain (dB) Pout 5 PAE (%) Pout LIF 0 0 P -10 -8 -6 -4 -2 0 2 4 6 -10 -8 -6 -4 -2 0 2 4 6 INPUT POWER (dBm) INPUT POWER (dBm) M K A
Output IP3 vs. Temperature Noise Figure vs. Temperature
C 36 16 LO 32 +25 C ) 12 +85 C -40 C (dB ) IN B 28 E R U A (dBm IG 8 F IP3 24 +25 C E +85 C IS -40 C O N 4 20 R & G E 16 0 2 4 6 8 10 12 14 16 18 20 6 8 10 12 14 16 18 IV FREQUENCY (GHz) FREQUENCY (GHz) R D
Gain & Power vs. Supply Voltage @ 12.5 GHz Reverse Isolation vs. Temperature
25 0 -10 Gain (dBm) 24 P1dB Psat -20 +25 C Psat ) +85 C -40 C 23 -30 (dB Bm), N (d IO -40 T 22 LA P1dB O -50 IS (dB), -60 21 GAIN -70 20 -80 4.5 4.7 4.9 5.1 5.3 5.5 2 4 6 8 10 12 14 16 18 20 22 24 Vdd (V) FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
