Datasheet HMC634 (Analog Devices)
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5 -20 GHz
Pages / Page8 / 1 — HMC634. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Typical …
File Format / SizePDF / 410 Kb
HMC634. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC634 Analog Devices
HMC634
v01.0308
GaAs PHEMT MMIC DRIVER AMPLIFIER, 5 - 20 GHz Typical Applications Features
2 Gain: 22 dB The HMC634 is ideal for: P1dB: +23 dBm • Point-to-Point Radios Output IP3: +31 dBm • Point- to-Multi-Point Radios & VSAT IP Saturated Power: 24 dBm @ 23% PAE • LO Driver for Mixers H Supply Voltage: +5 V @ 180 mA • Military & Space 50 Ohm Matched Input/Output - C S Die Size: 2.07 x 0.97 x 0.10 mm R IE
IF L The HMC634 is a GaAs MMIC PHEMT Driver P Amplifi er die which operates between 5 and 20 GHz. M The amplifi er provides up to 22 dB of gain, +31 dBm Output IP3, and up to +23 dBm of output power at 1 dB gain compression, while requiring 180 mA from a +5V K A supply. The HMC634 is an ideal driver amplifi er for microwave radio applications from 5 to 20 GHz, and OC may be biased at +5V, 130 mA to provide 2 dB lower gain with improved PAE. The HMC634 amplifi er I/O’s BL are DC blocked and internally matched to 50 Ohms IN facilitating easy integration into Multi-Chip-Modules A (MCMs). All data is taken with die connected at input and output RF ports via one 1 mil wedge bond with minimal length of 0.31 mm (12 mils). & G R E IV
Electrical Specifi cations, T = +25° C, Vdd1, Vdd2, Vdd3, Vdd4= 5V, Idd= 180mA[1]
R
A
D Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 5 - 16 16 - 20 GHz Gain 17 22 17 20 dB Gain Variation Over Temperature 0.030 0.040 0.025 0.035 dB/ °C Input Return Loss 12 9 dB Output Return Loss 12 11 dB Output Power for 1 dB Compression (P1dB) 21 23 18 21 dBm Saturated Output Power (Psat) 24 22 dBm Output Third Order Intercept (IP3) 31 30 dBm Noise Figure 7 7.5 dB Supply Current (Idd1 + Idd2 + Idd3 + Idd4) 180 180 mA
[1]
Adjust Vgg between -2 to 0V to achieve Idd = 180mA Ty pical Information furnis F he o d r pri by An ce, de alog Devic leiv s ies ry be , a lievend to pla d to be accurce o ate an rd der relia s bl , pl e. Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 50
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n25 lin 0- e a 3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hit A tpite.co plicatio m n Support: Phone: 1-800-ANALOG-D
