Datasheet HMC-AUH256 (Analog Devices) - 3
DescriptionGaAs HEMT MMIC DRIVER AMPLIFIER, 17.5 -41.0 GHz
Pages / Page6 / 3 — HMC-AUH256. GaAs HEMT MMIC DRIVER. AMPLIFIER, 17.5 - 41.0 GHz. Fixtured …
File Format / SizePDF / 425 Kb
HMC-AUH256. GaAs HEMT MMIC DRIVER. AMPLIFIER, 17.5 - 41.0 GHz. Fixtured Pout vs. x2 Pout vs. Frequency (vs Pad)
HMC-AUH256 GaAs HEMT MMIC DRIVER AMPLIFIER, 17.5 - 41.0 GHz Fixtured Pout vs x2 Pout vs Frequency (vs Pad)
HMC-AUH256
v01.0208
GaAs HEMT MMIC DRIVER AMPLIFIER, 17.5 - 41.0 GHz Fixtured Pout vs. x2 Pout vs. Frequency (vs Pad) Frequency @ Pin= 8 dBm
2 IP H - C S R IE IF L P M
Fixtured Pout vs. Absolute Maximum Ratings
K A
Frequency @ Pin= 10 dBm
Drain Bias Voltage +5.5 Vdc RF Input Power 15 dBm OC Drain Bias Current (Idd1, Idd2) 62 mA Drain Bias Current (Idd3) 93 mA BL Drain Bias Current (Idd4) 150 mA IN Gate Bias Voltage -1 to +0.3 Vdc A Channel Temperature 180 °C Thermal Resistance 77.5 °C/W (channel to die bottom) & G Storage Temperature -65 to +150 °C R E IV R D ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS Note: Multiplier Performance Characteristics (Typical Performance at 25°C) Vd1= 2V, Vd2= Vd3= Vd4= 5V, Id1= 5mA, Id2+Id3+Id4= 245mA Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 68
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
