Datasheet HMC594LC3B (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz
Pages / Page6 / 6 — HMC594LC3B. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Evaluation …
File Format / SizePDF / 366 Kb
HMC594LC3B. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Evaluation PCB. List of Materials for Evaluation PCB 109712 [1]
HMC594LC3B GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Evaluation PCB List of Materials for Evaluation PCB 109712 [1]
HMC594LC3B
v03.0514
T M E - S IS O W N O S - L R IE LIF P M A
The circuit board used in the application should use Item Description RF circuit design techniques. Signal lines should J1 - J2 SRI SMA Connector have 50 Ohm impedance while the package ground J3 - J6 DC Pin leads and exposed paddle should be connected C1 - C2 100 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C3 - C4 1000 pF Capacitor, 0603 Pkg. A sufficient number of via holes should be used to C5 - C6 2.2 µF Capacitor, Tantalum connect the top and bottom ground planes. The U1 HMC594LC3B Amplifier evaluation board should be mounted to an appro- PCB [2] 109710 Evaluation PCB, 10 mils priate heat sink. The evaluation circuit board shown [1] Reference this number when ordering complete evaluation PCB is available from Hittite upon request. [2] Circuit Board Material: Rogers 4350 Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
