HMC594 v01.0312 GaAs pHEMT MMIC LOW NOISEAMPLIFIER, 2 - 4 GHzAbsolute Maximum RatingsTypical Supply Current vs. Vdd Drain Bias Voltage (Vdd) +7 Vdc Vdd (Vdc) idd (mA) rf input power (rfiN)(Vdd = +6.0 Vdc) +15 dBm +5.5 97 Channel Temperature 175 °C +6.0 100 ip Continuous pdiss (T= 85 °C) +6.5 103 H 0.76 w (derate 11.7 mw/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown Thermal resistance above. 85 °C/w (channel to die bottom) e - C storage Temperature -65 to +150 °C operating Temperature -55 to +85 °C is eleCTrosTATiC seNsiTiVe DeViCe o oBserVe HANDliNG preCAUTioNs w N Outline Drawing lo s - r ie lif p m A NoTes: Die Packaging Information [1] 1. All DimeNsioNs Are iN iNCHes [mm] 2. Die THiCKNess is .004” standard Alternate 3. TYpiCAl BoND is .004” sQUAre 4. BACKsiDe meTAlliZATioN: GolD Gp-1 (Gel pack) [2] 5. BoND pAD meTAlliZATioN: GolD [1] Refer to the “Packaging Information” section for die 6. BACKsiDe meTAl is GroUND. 7. CoNNeCTioN NoT reQUireD for UNlABeleD BoND pADs. packaging dimensions. [2] For alternate packaging information contact Hittite Microwave Corporation. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 4 Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
