Datasheet HMC498LC4 (Analog Devices)
DescriptionGaAs PHEMT MEDIUM POWER AMPLIFIER, 17 - 24 GHz
Pages / Page6 / 1 — HMC498LC4. GaAs PHEMT MEDIUM. POWER AMPLIFIER, 17 - 24 GHz. Typical …
HMC498LC4. GaAs PHEMT MEDIUM. POWER AMPLIFIER, 17 - 24 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC498LC4 Analog Devices
HMC498LC4
v05.0418
GaAs PHEMT MEDIUM POWER AMPLIFIER, 17 - 24 GHz Typical Applications Features
The HMC498LC4 is ideal for use as a LNA or Driver Output IP3: +36 dBm T amplifier for: Saturated Power: +26 dBm @ 23% PAE M • Point-to-Point Radios Gain: 22 dB • Point-to-Multi-Point Radios & VSAT +5V @ 250 mA Supply S - S • Test Equipment & Sensors 50 Ohm Matched Input/Output R • Military End-Use RoHS Compliant 4x4 mm SMT Package IE LIF
P The HMC498LC4 is a high dynamic range GaAs M PHEMT MMIC Medium Power Amplifier housed in a leadless “Pb free” SMT package. Operating from 17 R A to 24 GHz, the amplifier provides 22 dB of gain, +26 E dBm of saturated power and 23% PAE from a +5V W supply voltage. Noise figure is 4 dB while output IP3 is O +36 dBm typical enabling the HMC498LC4 to function as a low noise front end as well as a driver amplifier. The RF I/Os are DC blocked and matched to 50 Ohms for ease of use. The HMC498LC4 eliminates the R & P need for wire bonding, al owing use of surface mount A manufacturing techniques. E LIN
Electrical Specifications, T = +25° C, Vdd1, 2, 3 = 5V, Idd = 250 mA* A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 17 - 19 19 - 23 23 - 24 GHz Gain 18 22 20 22.5 18 21 dB Gain Variation Over Temperature 0.02 0.03 0.02 0.03 0.02 0.03 dB/ °C Input Return Loss 13 13 10 dB Output Return Loss 15 15 20 dB Output Power for 1 dB Compression (P1dB) 22 25 21.5 24.5 22.5 25.5 dBm Saturated Output Power (Psat) 26.5 25.5 26.5 dBm Output Third Order Intercept (IP3) 35 36 35.5 dBm Noise Figure 4.0 4.0 4.5 dB Supply Current (Idd)(Vdd = +5V, Vgg = -0.8V 250 250 250 mA Typ.) * Adjust Vgg between -2 to 0V to achieve Idd = 250 mA typical. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
