Datasheet HMC498LC4 (Analog Devices) - 4
DescriptionGaAs PHEMT MEDIUM POWER AMPLIFIER, 17 - 24 GHz
Pages / Page6 / 4 — HMC498LC4. GaAs PHEMT MEDIUM. POWER AMPLIFIER, 17 - 24 GHz. Absolute …
HMC498LC4. GaAs PHEMT MEDIUM. POWER AMPLIFIER, 17 - 24 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC498LC4 GaAs PHEMT MEDIUM POWER AMPLIFIER, 17 - 24 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC498LC4
v05.0418
GaAs PHEMT MEDIUM POWER AMPLIFIER, 17 - 24 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) +5.5 Vdc Vdd (Vdc) Idd (mA) Gate Bias Voltage (Vgg) -4.0 to 0 Vdc +4.5 239 T RF Input Power (RFIN)(Vdd = +5Vdc) +10 dBm +5.0 250 M Channel Temperature 175 °C +5.5 262 Continuous Pdiss (T= 85 °C) 1.62 W (derate 18 mW/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown above. Vgg adjusted to achieve Idd= 250 mA at +5V. Thermal Resistance S - S 55.6 °C/W (channel to ground paddle) R Storage Temperature -65 to +150 °C IE Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE ESD Sensitivity (HBM) Class 1A OBSERVE HANDLING PRECAUTIONS LIF
24-Terminal Ceramic Leadless Chip Carrier [LCC] (E-24-1)
P
Dimensions shown in millimeters. Outline Drawing
M
4.05 0.36
R A
3.90 SQ 0.30
E
PIN 1 3.75 0.08 0.24 INDICATOR BSC PIN 1 19 24
W
18 1
O
0.50 BSC 2.60 EXPOSED PAD 2.50 SQ 2.40 13 6 12 7
R & P
TOP VIEW 0.32 BOTTOM VIEW BSC 2.50 REF
A
1.00 3.10 BSC
E
0.90 SIDE VIEW 0.80 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO THE PIN CONFIGURATION AND
LIN
SEATING FUNCTION DESCRIPTIONS PLANE SECTION OF THIS DATA SHEET. PKG-004840 02-27-2017-B
24-Terminal Ceramic Leadless Chip Carrier [LCC] (E-24-1) Dimensions shown in mil imeters.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC498LC4 Alumina, White Gold over Nickel MSL3 [1] H498 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
