Datasheet HMC442LM1 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 17.5 - 24.0 GHz
Pages / Page8 / 3 — HMC442LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 17.5 - 24.0 GHz. …
File Format / SizePDF / 417 Kb
HMC442LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 17.5 - 24.0 GHz. Power Compression @ 18 GHz. Power Compression @ 23 GHz
HMC442LM1 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 17.5 - 24.0 GHz Power Compression @ 18 GHz Power Compression @ 23 GHz
HMC442LM1
v01.0807
30 32 28 Pout (dBm) 25 Pout (dBm) Gain (dB) Gain (dB) 24 PAE (%) PAE (%) 20 20 15 16 11 12 10 8 5 Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) 4 T 0 0 -10 -6 -2 2 6 10 14 -10 -6 -2 2 6 10 14 INPUT POWER (dBm) INPUT POWER (dBm) - SM S
Output IP3 vs. Temperature Noise Figure vs. Temperature
34 10 30 8 PLIFIER M 26 6 GURE (dB) +25 C IP3 (dBm) 22 +85 C 4 SE FI -40 C ER A NOI + 25C 18 2 +85 C W -40 C O 14 0 16 18 20 22 24 26 16 18 20 22 24 26 FREQUENCY (GHz) FREQUENCY (GHz) & P R
Gain & Power vs.
A
Supply Voltage @ 23 GHz Reverse Isolation vs. Temperature
E 26 0 LIN 24 -10 22 +25 C -20 +85 C 20 -40 C Bm), Psat (dBm) 18 -30 16 ISOLATION (dB) -40 14 Gain P1dB -50 12 Psat GAIN (dB), P1dB (d 10 -60 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 16 17 18 19 20 21 22 23 24 25 26 27 Vdd Supply Voltage (Vdc) FREQUENCY (GHz) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 108
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
