Datasheet HMC442 (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC MEDIUM POWER AMPLIFIERS, 17.5 - 25.5 GHz
Pages / Page6 / 5 — HMC442. GaAs pHEMT MMIC MEDIUM. POWER AMPLIFIERS, 17.5 - 25.5 GHz. Pad …
File Format / SizePDF / 374 Kb
HMC442. GaAs pHEMT MMIC MEDIUM. POWER AMPLIFIERS, 17.5 - 25.5 GHz. Pad Descriptions. Assembly Diagram
HMC442 GaAs pHEMT MMIC MEDIUM POWER AMPLIFIERS, 17.5 - 25.5 GHz Pad Descriptions Assembly Diagram
HMC442
v04.0913
Pad Number Function Description Pin Schematic IP H Gate control for amplifier. Adjust to achieve Id of 85mA. 1 Vgg Please follow “MMIC Amplifier Biasing Procedure” Application Note. S - C R This pad is AC coupled 2 RFIN and matched to 50 Ohms IE LIF Power Supply Voltage for the amplifier. External 3 Vdd bypass P capacitors of 100 pF and 0.01 µF are required. M This pad is AC coupled 4 RFOUT and matched to 50 Ohms. R A E
Assembly Diagram
W O R & P A E LIN Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
