Datasheet HMC441LM1 (Analog Devices)
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz
Pages / Page9 / 1 — HMC441LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. Typical …
RevisionD
HMC441LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC441LM1 Analog Devices, Revision: D
HMC441LM1
v04.1019
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz Typical Applications Features
The HMC441LM1 is a medium PA for: Gain: 15 dB T • Point-to-Point Radios Saturated Power: +21.5 dBm @ 27% PAE M • Point-to-Multi-Point Radios Single Supply Voltage: +5V w/ Optional Gate Bias • VSAT S - S 50 Ohms Matched Input/Output • LO Driver for HMC Mixers R Leadless SMT Package, 25mm2 • Military EW & ECM IE LIF
P The HMC441LM1 is a broadband 7 to 15.5 GHz GaAs M PHEMT MMIC Medium Power Amplifier in an SMT leadless chip carrier package. The amplifier provides R A 15 dB of gain, 21.5 dBm of saturated power at 27% E PAE from a +5V supply voltage. An optional gate W bias is provided to al ow adjustment of gain, RF O output power, and DC power dissipation. This 50 Ohm matched amplifier does not require any external components making it an ideal linear gain block or driver for HMC SMT mixers. R & P A E LIN Vgg1, Vgg2: Optional Gate Bias
Electrical Specifications, T = +25° C, Vdd = 5V, Vgg1 = Vgg2 = Open A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 7.0 - 8.0 8.0 - 12.5 12.5 - 14.0 14.0 - 15.5 GHz Gain 12.5 15 13.5 16 12.5 15 11 13.5 dB Gain Variation Over Temperature 0.015 0.02 0.015 0.02 0.015 0.02 0.015 0.02 dB/ °C Input Return Loss 9 13 16 16 dB Output Return Loss 14 17 20 17 dB Output Power for 1 dB 15.5 18.5 16 19 17 20 16 19 dBm Compression (P1dB) Saturated Output Power (Psat) 19.5 20.5 21.5 20.5 dBm Output Third Order Intercept (IP3) 29 30 30 30 dBm Noise Figure 4.5 4.5 4.5 4.5 dB Supply Current (Idd) 90 115 90 115 90 115 90 115 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no respon- For price, delivery, and to place orders: Analog Devices, Inc., sibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
third parties that may result from its use. Specifications subject to change without notice. No license is Phone: 781-329-4700 • Order online at www.analog.com granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
