Datasheet HMC441LH5 (Analog Devices)
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz
Pages / Page6 / 1 — HMC441LH5. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. Typical …
HMC441LH5. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC441LH5 Analog Devices
HMC441LH5
v03.1017
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz Typical Applications Features
The HMC441LH5 is a medium PA for: Gain: 5 dB T • Telecom Infrastructure Saturated Power: +21.5 dBm @ 25% PAE M S • Military Radio, Radar & ECM Single Positive Supply: +5V • Space Systems 50 Ohms Matched Input/Output S - • Test Instrumentation Hermetic SMT Package, 25mm2 R Screening to MIL-PRF-38535 (Class B or S) Available IE LIF
P M The HMC441LH5 is a broadband 7 to 15.5 GHz GaAs PHEMT MMIC Medium Power Amplifier housed in a hermetic SMT leadless package. The amplifier R A provides 15 dB of gain and 21.5 dBm of saturated E power at 25% PAE from a +5V supply. This 50 Ohm W matched amplifier does not require any external O components, and the RF I/Os are DC blocked, P making it an ideal linear gain block or driver amplifier. The HMC441LH5 al ows the use of surface mount R & manufacturing techniques and is suitable for high A reliability military, industrial & space applications. E LIN
Electrical Specifications, T = +25° C, Vdd = 5V A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 7.0 - 8.0 8.0 - 13.0 13.0 - 14.0 14.0 - 15.5 GHz Gain 11 14 13 16 12 15 10.5 13.5 dB Gain Variation Over Temperature 0.015 0.02 0.015 0.02 0.015 0.02 0.015 0.02 dB/ °C Input Return Loss 11 13 10 8 dB Output Return Loss 10 15 14 12 dB Output Power for 1 dB 15.5 18.5 17 20 16 19 16 19 dBm Compression (P1dB) Saturated Output Power (Psat) 20 21 21.5 21 dBm Output Third Order Intercept (IP3) 30 32 32 32 dBm Noise Figure 5.0 4.75 4.75 5.0 dB Supply Current (Idd) 90 115 90 115 90 115 90 115 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
