Datasheet HMC407MS8G, 407MS8GE (Analog Devices) - 5
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz
Pages / Page6 / 5 — HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. …
File Format / SizePDF / 921 Kb
HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. Pin Descriptions. Application Circuit. 9 - 5
HMC407MS8G / 407MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz Pin Descriptions Application Circuit 9 - 5
v04.1019
Pin Number Function Description Interface Schematic Power supply voltage for the first amplifier stage. An external bypass capacitor 1 Vcc1 of 330 pF is required as shown in the application schematic. 9 T Power control pin. For maximum power, this pin should be connected to 5V. A 2 Vpd higher voltage is not recommended. For lower die current, this voltage can be M reduced. R - S Ground: Backside of package has exposed metal ground slug that must be E 3, 6, 7 GND connected to ground thru a short path. Vias under the device are required. W This pin is AC coupled O 4 RFIN and matched to 50 Ohms. This pin is AC coupled 5 RFOUT and matched to 50 Ohms. R & P Power supply voltage for the output amplifier stage. An external bypass A 8 Vcc2 capacitor of 330 pF is required. This capacitor should be placed no more than E 20 mils form package lead. IN
Application Circuit
S - L R IE LIF P M A Note 1: Vcc1 and Vcc2 may be connected to a common Vcc. Note 2: C2 should be located < 0.020” from Pin 8 (Vcc2). For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
9 - 5
Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
