Datasheet ADL8104 (Analog Devices) - 3
DescriptionWideband, High Linearity, Low Noise Amplifier, 0.4 GHz to 7.5 GHz
Pages / Page23 / 3 — Data Sheet. ADL8104. SPECIFICATIONS 0.4 GHz TO 0.6 GHz FREQUENCY RANGE. …
File Format / SizePDF / 625 Kb
Data Sheet. ADL8104. SPECIFICATIONS 0.4 GHz TO 0.6 GHz FREQUENCY RANGE. Table 1. Parameter. Min Typ. Max Unit
Data Sheet ADL8104 SPECIFICATIONS 0.4 GHz TO 0.6 GHz FREQUENCY RANGE Table 1 Parameter Min Typ Max Unit
VDD = 5 V, total supply current (IDQ) = 150 mA, RBIAS = 90.9 Ω, and TA = 25°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.4 0.6 GHz GAIN 11.5 14 dB Gain Variation over Temperature 0.036 dB/°C NOISE FIGURE 3.5 dB RETURN LOSS Input 12 dB Output 13 dB OUTPUT OP1dB 16.5 19 dBm Saturated Output Power (PSAT) 21 dBm OIP3 32 dBm Measurement taken at output power (POUT) per tone = 5 dBm OIP2 50 dBm Measurement taken at POUT per tone = 5 dBm POWER ADDED EFFICIENCY (PAE) 18 % Measured at PSAT
0.6 GHz TO 6 GHz FREQUENCY RANGE
VDD = 5 V, IDQ = 150 mA, RBIAS = 90.9 Ω, and TA = 25°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.6 6 GHz GAIN 12 15 dB Gain Variation over Temperature 0.030 dB/°C NOISE FIGURE 3.5 dB RETURN LOSS Input 12 dB Output 12 dB OUTPUT OP1dB 17.5 20 dBm PSAT 21 dBm OIP3 32 dBm Measurement taken at POUT per tone = 5 dBm OIP2 52 dBm Measurement taken at POUT per tone = 5 dBm PAE 12 % Measured at PSAT
6 GHz TO 7.5 GHz FREQUENCY RANGE
Table 3. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 6 7.5 GHz GAIN 10 13 dB Gain Variation over Temperature 0.041 dB/°C NOISE FIGURE 4.5 dB RETURN LOSS Input 12 dB Output 12 dB Rev. 0 | Page 3 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 0.6 GHz Frequency Range 0.6 GHz to 6 GHz Frequency Range 6 GHz to 7.5 GHz Frequency Range DC Specifications Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8104 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing Outline Dimensions Ordering Guide
