Datasheet HMC8412TCPZ-EP (Analog Devices) - 4
DescriptionLow Noise Amplifier, 0.4 GHz to 11 GHz
Pages / Page10 / 4 — HMC8412TCPZ-EP. Enhanced Product. 9 GHz TO 11 GHz FREQUENCY RANGE. Table …
File Format / SizePDF / 310 Kb
HMC8412TCPZ-EP. Enhanced Product. 9 GHz TO 11 GHz FREQUENCY RANGE. Table 3. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
HMC8412TCPZ-EP Enhanced Product 9 GHz TO 11 GHz FREQUENCY RANGE Table 3 Parameter Min Typ Max Unit Test Conditions/Comments
VDD = 5 V, IDQ = 60 mA, RBIAS = 1.47 kΩ, and TA = 25°C, unless otherwise noted.
Table 3. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 9 11 GHz GAIN 12 14 dB Gain Variation over Temperature 0.012 dB/°C NOISE FIGURE 1.8 dB RETURN LOSS Input 14 dB Output 10 dB OUTPUT OP1dB 11 14 dBm PSAT 18 dBm OIP3 31 dBm Measurement taken at POUT per tone = 0 dBm OIP2 49.5 dBm Measurement taken at POUT per tone = 0 dBm PAE 15.5 % Measured at PSAT SUPPLY IDQ 60 mA VDD 2 5 6 V Rev. 0 | Page 4 of 10 Document Outline Features Enhanced Product Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 3 GHz Frequency Range 3 GHz to 9 GHz Frequency Range 9 GHz to 11 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412TCPZ-EP Power Derating Curves ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Outline Dimensions Ordering Guide
