Datasheet HMC8412TCPZ-EP (Analog Devices) - 10
Description | Low Noise Amplifier, 0.4 GHz to 11 GHz |
Pages / Page | 10 / 10 — HMC8412TCPZ-EP. Enhanced Product. OUTLINE DIMENSIONS. 1.70. DETAIL A. … |
File Format / Size | PDF / 310 Kb |
HMC8412TCPZ-EP. Enhanced Product. OUTLINE DIMENSIONS. 1.70. DETAIL A. (JEDEC 95). 1.60. 2.05. 1.50. 2.00 SQ. 0.65. 1.95. BSC. PIN 1 INDEX. 1.10. AREA
link to page 5
HMC8412TCPZ-EP Enhanced Product OUTLINE DIMENSIONS 1.70 DETAIL A (JEDEC 95) 1.60 2.05 1.50 2.00 SQ 0.65 1.95 BSC 5 8 PIN 1 INDEX 1.10 AREA EXPOSED 1.00 PAD 0.90 P IN 1 0.30 4 1 IN D IC AT O R AR E A OP T IO N S (SEE DETAIL A) TOP VIEW 0.25 BOTTOM VIEW 0.20 1.30 REF 0.90 0.85 SIDE VIEW 0.05 MAX FOR PROPER CONNECTION OF 0.80 THE EXPOSED PAD, REFER TO 0.02 NOM THE PIN CONFIGURATION AND COPLANARITY FUNCTION DESCRIPTIONS 0.08 0.35 SECTION OF THIS DATA SHEET. A SEATING PLANE 0.30 0.203 REF 2018- -005241 G 0.25 17- K P 08-
Figure 23. 6-Lead Lead Frame Chip Scale Package [LFCSP] 2 mm × 2 mm Body and 0.85 mm Package Height (CP-6-12) Dimensions shown in millimeters
ORDERING GUIDE Model1 Temperature Range MSL Rating2 Package Description3 Package Option
HMC8412TCPZ-EP-PT −55°C to +125°C MSL1 6-Lead Lead Frame Chip Scale Package [LFCSP] CP-6-12 HMC8412TCPZ-EP-R7 −55°C to +125°C MSL1 6-Lead Lead Frame Chip Scale Package [LFCSP] CP-6-12 1 The HMC8412TCPZ-EP-PT and HMC8412TCPZ-EP-R7 are RoHS compliant parts. 2 See the Absolute Maximum Ratings section for additional information. 3 The lead finish of the HMC8412TCPZ-EP-PT and HMC8412TCPZ-EP-R7 is nickel palladium gold (NiPdAu).
©2020 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D25386-10/20(0)
Rev. 0 | Page 10 of 10 Document Outline Features Enhanced Product Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 3 GHz Frequency Range 3 GHz to 9 GHz Frequency Range 9 GHz to 11 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412TCPZ-EP Power Derating Curves ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Outline Dimensions Ordering Guide
