Datasheet ADL9005 (Analog Devices) - 10
DescriptionWideband, Low Noise Amplifier, Single Positive Supply, 0.01 GHz to 26.5 GHz
Pages / Page24 / 10 — ADL9005. Data Sheet. 1.5kΩ, I. DQ = 40mA. 1kΩ, I. DQ = 50mA. 650Ω, I. DQ …
File Format / SizePDF / 624 Kb
ADL9005. Data Sheet. 1.5kΩ, I. DQ = 40mA. 1kΩ, I. DQ = 50mA. 650Ω, I. DQ = 60mA. 450Ω, I. DQ = 70mA. 300Ω, IDQ = 80mA. 180Ω, IDQ = 90mA
ADL9005 Data Sheet 1.5kΩ, I DQ = 40mA 1kΩ, I DQ = 50mA 650Ω, I DQ = 60mA 450Ω, I DQ = 70mA 300Ω, IDQ = 80mA 180Ω, IDQ = 90mA
ADL9005 Data Sheet 0 0 1.5kΩ, I 3V DQ = 40mA 1kΩ, I 4V DQ = 50mA 650Ω, I 5V DQ = 60mA 450Ω, I B) 6V –5 DQ = 70mA B) d –5 d ( ( 300Ω, IDQ = 80mA S S S S 180Ω, IDQ = 90mA O O URN L –10 URN L –10 T T RE RE UT UT P P UT –15 UT –15 O O –20 –20 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28
019
022
FREQUENCY (GHz)
25033-
FREQUENCY (GHz)
25033- Figure 19. Output Return Loss vs. Frequency at Various VDD, Figure 22. Output Return Loss vs. Frequency for Various Bias Resistor Values IDQ = 80mA, 0.01 GHz to 28 GHz and IDQ, 0.01 GHz to 28 GHz, VDD = 5 V
0 0 –40°C –5 +25°C –40°C –5 +85°C +25°C ) +85°C ) –10 –10 dB dB ( ( –15 –15 TION TION A A L L –20 –20 SO SO SE I SE I –25 –25 EVER EVER R –30 R –30 –35 –35 –40 –40 0 20 40 60 80 100 120 140 160 180 200
020 023
0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 FREQUENCY (MHz) FREQUENCY (GHz)
25033- 25033- Figure 20. Reverse Isolation (S12) vs. Frequency for Various Temperatures, Figure 23. Reverse Isolation vs. Frequency for Various Temperatures, 10 MHz to 200 MHz, VDD = 5 V, VBIAS = 5 V, IDQ = 80 mA, RBIAS = 300 Ω 0.2 GHz to 28 GHz, VDD = 5 V, VBIAS = 5 V, IDQ = 80 mA, RBIAS = 300 Ω
0 0 3V 1.5kΩ, I –5 DQ = 40mA –5 4V 1kΩ, IDQ = 50mA 5V ) ) 650Ω, I –10 DQ = 60mA –10 6V dB dB 450Ω, IDQ = 70mA ( ( 300Ω, IDQ = 80mA –15 –15 180Ω, I TION DQ = 90mA TION A A L L –20 –20 SO SO SE I –25 SE I –25 EVER EVER R –30 R –30 –35 –35 –40 –40 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28
021
024
FREQUENCY (GHz)
25033-
FREQUENCY (GHz)
25033- Figure 21. Reverse Isolation vs. Frequency for Various VDD, Figure 24. Reverse Isolation vs. Frequency for Various Bias Resistor Values IDQ = 80 mA, 0.01 GHz to 28 GHz and IDQ, 0.01 GHz to 28 GHz, VDD = 5 V Rev. 0 | Page 10 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.01 GHz TO 14 GHz 14 GHz TO 20 GHz 20 GHz TO 26.5 GHz DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADL9005 ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS BIASING THROUGH THE ACG4/VDD2 PIN THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS BIASING THE ADL9005 BY USING THE LTM8020 PROVIDING DRAIN BIAS PROVIDING DRAIN BIAS THROUGH THE ACG4/VDD2 PIN POWER-UP AND POWER-DOWN SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
