Datasheet HMC8325 (Analog Devices) - 9
Description | 71 GHz to 86 GHz, E-Band Low Noise Amplifier |
Pages / Page | 16 / 9 — Data Sheet. HMC8325. D3/ID4 = 1.5mA. ID3/ID4 = 15.0mA. D3/ID4 = 3.0mA. … |
File Format / Size | PDF / 310 Kb |
Data Sheet. HMC8325. D3/ID4 = 1.5mA. ID3/ID4 = 15.0mA. D3/ID4 = 3.0mA. D3/ID4 = 25.0mA. ID3/ID4 = 20.0mA. D3/ID4 = 5.0mA
Data Sheet HMC8325 10 10 I I I D3/ID4 = 1.5mA ID3/ID4 = 15.0mA D3/ID4 = 3.0mA D3/ID4 = 25.0mA 9 I I I D3/ID4 = 3.0mA ID3/ID4 = 20.0mA D3/ID4 = 5.0mA D3/ID4 = 30.0mA I I I D3/ID4 = 5.0mA ID3/ID4 = 25.0mA D3/ID4 = 10.0mA D3/ID4 = 35.0mA I I ID3/ID4 = 15.0mA ID3/ID4 = 40.0mA 8 D3/ID4 = 10.0mA D3/ID4 = 30.0mA 8 ID3/ID4 = 20.0mA ID3/ID4 = 44.0mA ) 7 ) dB dB ( ( E 6 6 E R R 5 FIGU FIGU E E 4 4 OIS OIS N 3 N 2 2 1 0 0 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
026
029
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 26. Noise Figure vs. Frequency over Drain Current, VDx = 4 V, Figure 29. Noise Figure vs. Frequency over Drain Current, VG1 and VG2 Fixed at 20 mA, VG3 and VG4 Swept VD1 and VD2 = 2 V, VD3 and VD4 = 4 V
20 20 T 18 A = +85°C 19 TA = +25°C TA = –55°C 16 18 14 17 Bm) d 12 16 B ( Bm) 1d d 10 ( 15 P AT UT S P 8 P 14 UT O 6 13 4 12 TA = +85°C T 2 A = +25°C 11 TA = –55°C 0 10 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
027
030
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 27. Output P1dB vs. Frequency over Temperature, Figure 30. Saturated Output Power (PSAT) vs. Frequency over Temperature, VDx = 4 V, IDx = 50 mA VDx = 4 V, IDx = 50 mA
20 20 ID3/ID4 = 3.0mA ID3/ID4 = 20.0mA ID3/ID4 = 3.0mA ID3/ID4 = 20.0mA 18 ID3/ID4 = 5.0mA ID3/ID4 = 25.0mA 19 ID3/ID4 = 5.0mA ID3/ID4 = 25.0mA ID3/ID4 = 10.0mA ID3/ID4 = 30.0mA ID3/ID4 = 10.0mA ID3/ID4 = 30.0mA I I 16 D3/ID4 = 15.0mA 18 D3/ID4 = 15.0mA 14 17 Bm) d 12 16 B ( Bm) 1d d 10 ( 15 P AT UT S P 8 P 14 UT O 6 13 4 12 2 11 0 10 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
028
031
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 28. Output P1dB vs. Frequency over Drain Current, VDx = 3 V, Figure 31. Saturated Output Power (PSAT) vs. Frequency over Drain Current, VG1 and VG2 Fixed at 20 mA, VG3 and VG4 Swept VDx = 3 V, VG1 and VG2 Fixed at 20 mA, VG3 and VG4 Swept Rev. 0 | Page 9 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
