Datasheet ADL7003 (Analog Devices)
Description | 50 GHz to 95 GHz, GaAs, pHEMT, MMIC, Wideband Low Noise Amplifier |
Pages / Page | 18 / 1 — 50 GHz to 95 GHz, GaAs, pHEMT, MMIC,. Wideband Low Noise Amplifier. Data … |
File Format / Size | PDF / 486 Kb |
50 GHz to 95 GHz, GaAs, pHEMT, MMIC,. Wideband Low Noise Amplifier. Data Sheet. ADL7003. FEATURES. FUNCTIONAL BLOCK DIAGRAM
50 GHz to 95 GHz, GaAs, pHEMT, MMIC, Wideband Low Noise Amplifier Data Sheet ADL7003 FEATURES FUNCTIONAL BLOCK DIAGRAM Gain: 14 dB typical Noise figure: 5 dB typical 2 3 4 5 6 7 Input return loss (S11): 15 dB typical 1A 2A 3A 4A 12A 34A Output return loss (S22): 20 dB typical DD DD DD DD GG V V GG V V V V Output power for 1 dB compression (P1dB): 14 dBm typical Saturated output power (PSAT): 18 dBm typical Output third-order intercept (IP3): 21 dBm typical Supply voltage: 3 V at 120 mA RFOUT 50 Ω matched input/output 8 Die size: 1.9 mm × 1.9 mm × 0.05 mm APPLICATIONS ADL7003 Test instrumentation RFIN 1 Military and space Telecommunications infrastructure 12B 1B 2B 34B 3B 4B GG DD DD GG DD DD V V V V V V 14 13 12 11 10 9
001 15691- Figure 1.
GENERAL DESCRIPTION
The ADL7003 is a gal ium arsenide (GaAs), pseudomorphic to 90 GHz, the ADL7003 provides 15 dB (typical) of gain, high electron mobility transistor (pHEMT), monolithic 21 dBm output IP3, and 14 dBm of output power for1 dB gain microwave integrated circuit (MMIC), balanced low noise compression. The ADL7003 requires 120 mA from a 3 V supply. amplifier that operates from 50 GHz to 95 GHz. In the lower The ADL7003 amplifier inputs/outputs are internal y matched band of 50 GHz to 70 GHz, the ADL7003 provides 14 dB to 50 Ω, facilitating integration into multichip modules (MCMs). (typical) of gain, 21 dBm output IP3, and 12 dBm of output Al data is taken with the chip connected via one 0.076 mm (3 mil) power for 1 dB gain compression. In the upper band of 70 GHz ribbon bond of 0.076 mm (3 mil) minimal length.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibilty is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 50 GHz TO 70 GHz FREQUENCY RANGE 70 GHz TO 90 GHz FREQUENCY RANGE 90 GHz TO 95 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATIC TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
