Datasheet HMC8410 (Analog Devices)
Description | 0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier |
Pages / Page | 17 / 1 — 0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. … |
Revision | D |
File Format / Size | PDF / 684 Kb |
0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. HMC8410. FEATURES. FUNCTIONAL BLOCK DIAGRAM
0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier Data Sheet HMC8410 FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise figure: 1.1 dB typical HMC8410 High gain: 19.5 dB typical High output third-order intercept (IP3): 33 dBm typical 6-lead, 2 mm × 2 mm LFCSP package RFIN/VGG1 RFOUT/VDD APPLICATIONS
001
Software defined radios
14657-
Electronic warfare
Figure 1.
Radar applications GENERAL DESCRIPTION
The HMC8410 is a gallium arsenide (GaAs), monolithic The HMC8410 also features inputs/outputs (I/Os) that are microwave integrated circuit (MMIC), pseudomorphic high internal y matched to 50 Ω, making it ideal for surface-mounted electron mobility transistor (pHEMT), low noise wideband technology (SMT)-based, high capacity microwave radio amplifier that operates from 0.01 GHz to 10 GHz. The HMC8410 applications. provides a typical gain of 19.5 dB, a 1.1 dB typical noise figure, The HMC8410 is housed in a RoHS-compliant, 2 mm × 2 mm, and a typical output IP3 of 33 dBm, requiring only 65 mA from LFCSP package. a 5 V supply voltage. The saturated output power (PSAT) of up to 22.5 dBm enables the low noise amplifier (LNA) to function as a Multifunction pin names can be referenced by their relevant local oscillator (LO) driver for many of Analog Devices, Inc., function only. balanced, I/Q or image rejection mixers.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY ELECTRICAL SPECIFICATIONS 0.01 GHz TO 3 GHz FREQUENCY RANGE 3 GHz TO 8 GHz FREQUENCY RANGE 8 GHz TO 10 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING During Power-Up During Power-Down TYPICAL APPLICATION CIRCUIT EVALUATION BOARD EVALUATION BOARD SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
