Datasheet HMC8410 (Analog Devices) - 4
Description0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page17 / 4 — HMC8410. Data Sheet. 8 GHz TO 10 GHz FREQUENCY RANGE. Table 3. Parameter. …
RevisionD
File Format / SizePDF / 684 Kb
HMC8410. Data Sheet. 8 GHz TO 10 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
HMC8410 Data Sheet 8 GHz TO 10 GHz FREQUENCY RANGE Table 3 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
TA = 25°C, VDD = 5 V, and IDQ = 65 mA, unless otherwise noted.
Table 3. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 8 10 GHz GAIN 13 16 dB Gain Variation Over Temperature 0.01 dB/°C NOISE FIGURE 1.7 2.2 dB RETURN LOSS Input 8 dB Output 7 dB OUTPUT Output Power for 1 dB Compression P1dB 17.5 19.5 dBm Saturated Output Power PSAT 21.5 dBm Output Third-Order Intercept IP3 33 dBm SUPPLY CURRENT IDQ 65 80 mA Adjust VGG1 to achieve IDQ = 65 mA typical SUPPLY VOLTAGE VDD 2 5 6 V Rev. D | Page 4 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY ELECTRICAL SPECIFICATIONS 0.01 GHz TO 3 GHz FREQUENCY RANGE 3 GHz TO 8 GHz FREQUENCY RANGE 8 GHz TO 10 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING During Power-Up During Power-Down TYPICAL APPLICATION CIRCUIT EVALUATION BOARD EVALUATION BOARD SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
