Datasheet HMC8410CHIPS (Analog Devices)
Description | 0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier |
Pages / Page | 17 / 1 — 0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. … |
Revision | C |
File Format / Size | PDF / 427 Kb |
0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. HMC8410CHIPS. FEATURES. FUNCTIONAL BLOCK DIAGRAM
![Datasheet HMC8410CHIPS Analog Devices, Revision: C](https://www.rlocman.ru/datasheet/img.php?di=172113)
0.01 GHz to 10 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier Data Sheet HMC8410CHIPS FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise figure: 1.1 dB typical High gain: 19.5 dB typical High output third order intercept (IP3): 33 dBm typical 2 RFOUT/VDD Die size: 0.945 mm × 0.61 × 0.102 mm RFIN/V
01
GG1 1
0
HMC8410CHIPS
93-
150 Figure 1.
Software defined radios Electronic warfare Radar applications GENERAL DESCRIPTION
The HMC8410CHIPS is a gallium arsenide (GaAs), monolithic output power (PSAT) of 22.5 dBm enables the low noise amplifier microwave integrated circuit (MMIC), pseudomorphic high (LNA) to function as a local oscillator (LO) driver for many of electron mobility transistor (pHEMT), low noise, wideband Analog Devices, Inc., balanced, I/Q or image rejection mixers. amplifier that operates over a 0.01 GHz to 10 GHz frequency The HMC8410CHIPS also features inputs/outputs internally range. The HMC8410CHIPS provides a typical gain of 19.5 dB, matched to 50 Ω, making the device ideal for surface mounted a 1.1 dB typical noise figure, and a typical output IP3 of 33 dBm, technology (SMT)-based, high capacity microwave radio requiring only 65 mA from a 5 V supply voltage. The saturated applications.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2016–2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.01 GHz TO 3 GHz FREQUENCY RANGE 3 GHz TO 8 GHz FREQUENCY RANGE 8 GHz TO 10 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
