Datasheet HMC8402 (Analog Devices) - 4
Description2 GHz to 30 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page15 / 4 — HMC8402. Data Sheet. 26 GHz TO 30 GHz FREQUENCY RANGE. Table 3. …
RevisionE
File Format / SizePDF / 380 Kb
HMC8402. Data Sheet. 26 GHz TO 30 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
HMC8402 Data Sheet 26 GHz TO 30 GHz FREQUENCY RANGE Table 3 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
TA = 25°C, VDD = 7 V, IDQ = 74 mA.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 26 30 GHz GAIN 11 13 dB Gain Variation Over Temperature 0.009 dB/°C RETURN LOSS Input 10 dB Output 10 dB OUTPUT Output Power for 1 dB Compression P1dB 15 19 dBm Saturated Output Power PSAT 20.5 dBm Output Third Order Intercept IP3 Measurement taken at POUT/tone = 0 dBm 23 dBm NOISE FIGURE NF 3.0 4.5 dB SUPPLY CURRENT Total Supply Current IDQ Nominal voltage (VDD) = 7 V 45 68 85 mA Total Supply Current vs. VDD IDQ VDD = 5 V 62 mA VDD = 6 V 65 mA VDD = 7 V 68 mA VDD = 8 V 72 mA SUPPLY VOLTAGE VDD 5 7 8 V Rev. E | Page 4 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS 2 GHz TO 18 GHz FREQUENCY RANGE 18 GHz TO 26 GHz FREQUENCY RANGE 26 GHz TO 30 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BIASING PROCEDURES MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
